T500 water supply from a shower fitting..
Info specific to the T500
Postby MrCat » Thu Dec 30, 2010 9:02 am
The best place for me to run the T500 is in the bathroom but I\'ve got a strange size mixer tap and haven\'t been able to use the needle valve supplied with the T500.
So - I got the 20 mm adaptor for the T500 hoping that this would convert to something and found the thread is a 3/4\" bsp female thread. This fits practically nothing in our house but would work with a garden hose...
When I\'ve run the T500 I\'ve been using either the tap adaptor that came with the reflux or a barbed adaptor that goes on a shower fitting.
A quick trip round B&Q plumbing section today found a 1/2\" female to 3/4\" male connector.
So - remove the shower hose from the mixer tap, screw the female end of the adaptor onto the mixer tap, wrap a bit of PTFE tape around the the thread, screw the 20mm still spirits onto that and the needle valve onto that and it makes a lovely water tight fitting :)
I hope this helps someone else out as it was a real pain finding something that worked !!
MrCat
Postby short2 » Thu Dec 30, 2010 3:47 pm
Are you still marrieMrcat.
short2
Postby MrCat » Thu Dec 30, 2010 5:23 pm
I don\'t think I\'ve ever been Marie :)
MrCat
Postby short2 » Thu Dec 30, 2010 10:41 pm
Lucky you
short2
Postby jahtubs » Fri Dec 31, 2010 6:27 pm
Thanks for the tip MrCat - I\'ve been in the same boat and was wondering whether the shower mixer could work. I don\'t suppose you have the product number for the adapter from B&Q do you?
jahtubs
Postby MrCat » Sat Jan 01, 2011 12:35 am
I kept the package but there is no code on it.
It's a plumbsure multi-fit bush 1/2" female * 5/8" female * 3/4" male
Bar code is 0389 3159.
I'll see if I can find the receipt and get the code off that
MrCat
Postby jahtubs » Tue Jan 04, 2011 6:05 pm
Thanks MrCat that should be more than enough information to track it down. Cheers!
jahtubs
Return to T500
