Converting a T500 for a large botanical basket
Postby BlackMountains » Sun Feb 11, 2018 9:02 am
Hi has anyone built a column to go in top of the Alembic copper dome and reconnecting the condenser on the top . I want to mesh this at the bottom and use it as a gin basket
I have a still spirits botanical basket, but it’s quite small
I have the plumbing ability and access to 2” copper pipe and fittings just curious on the length I can make it .
Thanks
BlackMountains
Re: Converting a T500 for a large botanical basket
Postby H12rpo » Sun Feb 11, 2018 6:27 pm
I haven’t, but if you’re looking to sell the SS one.....I might take it? :)
H12rpo
Postby jonx69 » Mon Feb 12, 2018 8:08 am
I'm currently planning on trying this to make a reflux column, using 2" tri clamp fittings,they haven't arrived yet so can't say if it works or not.
http://www.ebay.co.uk/itm/2-51MM-Sanita ... 6ZTXKVcafA
http://www.ebay.co.uk/itm/1-1-2-DN40-Sa ... 2749.l2649
jonx69
Postby BlackMountains » Mon Feb 12, 2018 8:40 am
H12rpo wrote:I haven’t, but if you’re looking to sell the SS one.....I might take it? :)
Hi will be keeping the stainless reflux one if that’s what you mean .
BlackMountains
Postby BlackMountains » Mon Feb 12, 2018 8:55 am
jonx69 wrote:I'm currently planning on trying this to make a reflux column, using 2" tri clamp fittings,they haven't arrived yet so can't say if it works or not.
They look perfect, thanks , are you happy with the 1 1/2fitting I assume it’s bsp and will match the dome fitting etc .
The column only has one clamp by the look of it so will need another.
Thanks again
BlackMountains
Postby jonx69 » Mon Feb 12, 2018 9:28 am
Thanks again
From reading around the fitting on the copper condenser is 1.5" bsp so should fit, some of the Chinese fittings are NPT so watch out for that.
I didn't list all the parts I ordered, so you will need appropriate gaskets and clamps, and possibly some kind of silicone washer to go in the condenser head to marry up when you screw the tri clamp fitting.
jonx69
Postby BlackMountains » Wed Feb 14, 2018 4:23 pm
Great thanks for the update, ive gone ahead and ordered the kit and some spare gaskets and tri clamps .
I'm a heating engineer by trade so will be able to put this together some how lol .
this should give me a nice botanical basket. i have a still spirits gins basket so hopefully the threads will match the adaptor piece as that will give me a mesh base to stop the botanical falling through .
next up is a bubble plate set up , if you know of a chinese supplier
thanks for the help
BlackMountains
Postby jonx69 » Thu Feb 15, 2018 7:52 am
BlackMountains wrote:Great thanks for the update, ive gone ahead and ordered the kit and some spare gaskets and tri clamps .
thanks for the help
Pipe and fittings arrived yesterday, both fittings screw to each part of the condenser ,I might wrap some Teflon tape to make sure there sealed. the gasket is quite hard compared to the silicone ones I already have from still dragon, PTFE, so should be ok.
I'm yet to do any kind of column stilling, only just upgraded from the airstill, so someone else can hopefully help you with the bubble plates :)
jonx69
Postby BlackMountains » Thu Feb 15, 2018 7:55 am
Perfect stuff, could you put a picture up if you don’t mind . I also picked up a 2”sight glass for the fun of it , pretty and shiny , couldn’t resist .
BlackMountains
Postby jonx69 » Thu Feb 15, 2018 8:32 am
BlackMountains wrote:Perfect stuff, could you put a picture up if you don’t mind . I also picked up a 2”sight glass for the fun of it , pretty and shiny , couldn’t resist .
;D so did I (sight glass), my plan is 2x2" tubes (packed with SS scrubbies), sight glass, 2" Dephlegmator , condenser. I'ts all a bit mcgyver but hopefully I'll get something out of it.
forgot to mention a power controller, think this is a must on the T500 for spirit runs.
cheers
jonx69
Postby BlackMountains » Sat Feb 17, 2018 6:57 am
Perfect job, get it into service now,
Shame the same supplier doesn’t do condensers, I’m on the hunt for one .
Messaged so still dragons twice CO now with zero response !
BlackMountains
Postby BlackMountains » Sat Feb 17, 2018 10:51 am
This is one I picked up . Using it today and it’s doing the job, running the ss Alembic still at half power and so far so good
https://www.ebay.co.uk/itm/282425934168
BlackMountains
Postby BlackMountains » Sat Feb 17, 2018 5:10 pm
cheers
Can confirm that the power controller that I posted above works a treat . Tamed the rush in the T500 no problem
BlackMountains
Postby jonx69 » Sat Feb 17, 2018 6:00 pm
BlackMountains wrote:This is one I picked up . Using it today and it’s doing the job, running the ss Alembic still at half power and so far so good
That's the one I have too, not used it yet, still waiting for some parts.
jonx69
Postby BlackMountains » Wed Feb 28, 2018 6:54 am
Jonx , how did you geget on with your build .?
BlackMountains
