My First run with a T500
Info specific to the T500
Postby cmbtsmrf » Sat Dec 07, 2013 4:11 pm
Hi All,
So I borrowed a T500 from my buddy to try out. Last night I set it up, got 25L of my wash running and made sure the outlet temp was 55c as best I could. It dripped sooo painfully slow that I gave up after about 4 hours.
Today, I got up early, plugged the unit in, heated it up and played with the temp. At 63c the nectar started flowing and after 3 hours, collected 3.7L total at an amazing 95% !!! No smell to it, and was amazed at it being 95% ! I called my buddy and told him what happened and he informed me that he forgot to mention that it needs to be hotter than the manual says. I guess every machine is different.
In closing. I love this thing. Soo much better than my airstill for making neutrals. Could not believe the yield and percentage. The airstill doesn't come close.
Cmbtsmrf
cmbtsmrf
Re: My First run with a T500
Postby Admiral Toad » Sat Dec 07, 2013 4:19 pm
Yeah I found 63 was about right any warmer it goes faster but quality drops and vica versa
A double distillation will smooth it further
Admiral Toad
Stills: pothead, BP column
Postby Termite » Tue Dec 10, 2013 4:52 pm
I've been targeting 53-54 when using mine, but only from reading here that the slow = better quality.
Might try a batch on a higher temp and see, but this time round I also took some heads out (about 250 fores + 250 heads) then the last 700ml as tails.
But as with you - LOVE IT :) I've a great stock in my cupboard now, with another batch to start fermenting. Still messing with flavours, but mainly drink gin anyway and the Essencia Blue Gin is more than drinkable :)
Termite
Postby Superslim007 » Tue Dec 10, 2013 9:33 pm
I try to run mine at about 58 ish and find that after the 1 hour to get her running I'm about spent after 2 hours with circa 93%
Live Long and Prosper !!
Superslim007
Stills: SS T500
Return to T500
