Hydrometer
Hydrometer
Postby Admiral Toad » Mon Jun 04, 2012 12:20 pm
Now that I'm doing stripping runs does anyone know where I can get hold of an alcohol hyrometer that is accurate in the lower percentages ? ???
Admiral Toad
Stills: pothead, BP column
Re: Hydrometer
Postby Capt-Cudellez » Mon Jun 04, 2012 1:37 pm
BTW I have a few narrow range meters - they are massive next compared to a standard alcometer, no way will it fit in a parrot.
Also if you are looking for an accurate way of determining when all the alcohol is depleted from the boiler - the cheapest way would be to put a thermo in the still head - run it till it reads 99oC.
Personally I don't bother- I use the standard 0-100 alcometer, when it reads 15% and the output taste like water then I quit stripping.
Re: Hydrometer
Postby Almanac » Tue Jun 05, 2012 1:14 am
What CC said! What else you want?
Re: Hydrometer
Postby Admiral Toad » Tue Jun 05, 2012 7:50 am
Sorry just like gadgets. as it is doing what CC says so at 25 quid each I will 'Had me gob' , >:D ;D :D
Admiral Toad
Return to Distillation
