Building Vino Tinto's Pothead.
Info specific to the T500
Postby Icefever » Sun Mar 16, 2014 5:10 pm
I managed to make a start on building my pothead following the plan & photo of VT's build.
The BIG problem was my pipe cutter don't go big enough for a 2" pipe. So I used the disc cutter...so what...it worked out ok.
So I now have the column...all I need to do now is complete the liebig and I'm ready.
All it needs is the buffer mop and "it'll shine like the top of the Chrysler building"
Re: Building Vino Tinto's Pothead.
Postby fuf » Sun Mar 16, 2014 10:13 pm
Blimey BJ, you don't waste any time mate ;)
fuf.... :
Nil illegitimi carborundum
fuf
Stills: T500 + SPP
Postby Icefever » Mon Mar 17, 2014 6:22 am
Cheers Fuf..
I've had the pipe & fittings for a week or two now, I just want to get into making something with a bit more taste. The swmbo & me have had enough vodka for a while. :D :D
The build is very easy it's just a case of making sure all the joints are nice and clean before you start to solder. ;)
Postby Icefever » Sat May 10, 2014 11:30 am
Taken longer than I thought but I'm almost there...I spent yesterday soaking the column and liebig in a bucket of citric acid to clean off all the crap...it's now got a bit of a shine...all it needs now is a quick polish.
I thought I'd got a 45% elbow to change the angle of the dangle in my box of bits but no...so I'll have to get one... :D
It fit's the boiler ok so all I need now is a quick vinegar run. 8) and a cleaner wash.
Postby fuf » Sat May 10, 2014 7:24 pm
Image Nice job BJ
fuf.... :
fuf
Stills: T500 + SPP
Postby Icefever » Sat May 10, 2014 7:42 pm
Cheers Fuf....I think you'll get yours up & running before me mate. ;)
Postby vino-tinto » Sun May 11, 2014 6:17 am
Well done mate, hope you have fun. ;D ;D ;D
vino-tinto
Return to T500
