About to upset the purists
Re: About to upset the purists
Postby Easydrinker » Mon Feb 13, 2017 12:00 am
Casper wrote:Our sweetest Irish whiskey, Jameson's, uses maize spirit which is refluxed to 95+% and blended with potstill malt. Tullamore Dew is another example.
I don't believe that to be true, visit the Jameson website and see what they say.
Postby tasleBHC » Mon Feb 13, 2017 1:56 am
Thunderbird wrote:A"single malt" is just that in my book; basically a whisky made from malted barley by a single distillery. That's it. Start messing with this and you don't have single malt anymore. Start adding corn and rye to the mash and you end up with Jack Daniel's, which I love, and yes, if I had to describe it compared to a single malt scotch (which I also love), I'd say there was a hint of sweetness as you say, BUT..........
If you check out the section about barrels on the Jack Daniel's website it explains that the charring of the white oak barrels releases sugars which are taken up by the whiskey. When the sugars have been used up the barrels are shipped to Scotland to make scotch. So fundamentally, it's the wood which imparts the sweetness and not the mash.
that is an impressive bit of knowledge about JD fella.. i didnt know that about the barrels.. i knew the barrel impart some flavour but not that the old JD barrels end up n bonny scotland
I paint artistic pictures, I drink, I dig for victorian bottles...oh and i like to drink.
tasleBHC
Stills: airs till
Postby tasleBHC » Mon Feb 13, 2017 5:45 am
Anavrin wrote:You should seriously consider making a UJSM, fresh off the Still it is a sweet whisky, I liked it so much I have kept some to drink unaged before putting the rest on oak.
Apparently over time it does loose its corn flavour so if unaged it needs drinking, it's essentially what Tim and Tickle are making in the moonshiners TV program, however with UJSM you recycle backset to make it a sour mash.
this advice is the standard for creating a sour mash whiskey..I read that adding backwash 25% is part of the sour mash process gaining a consistent produce.. I could be wrong but I'm sure it the right process
tasleBHC
Stills: airs till
Postby Casper » Mon Feb 13, 2017 3:54 pm
Mash wrote:I have a massive mod I am going to do on my BM to make the job a whole lot easier then. Boom. Whiskey.
Do tell more.
I have just adapted my stovetop too. A 3" Y welded into the lid with a 45° and 90° welded to one arm. Removeable screw on lid to short arm, reducer to Liebig on the other. All SS. Works a treat
Casper
Stills: SSpot&reflux
Postby tasleBHC » Wed Feb 15, 2017 12:26 am
whats a `BM ? i am slightly conusfed with all the terminology.. newb and that.. doh
I don't think feints are used for Bourbon style Whisky, they recycle backset from the boiler into the next mash to make it a sour mash.
i read this in th book about sour mash and moonshine distilling it takes 25% backwash to make a sour mash JD and thats a standard practise. i dont think any short cut corners will ever achieve that subtlety of which mr Daniels got from a time honoured practice.. i as a newb could be wrong tho ;)
tasleBHC
Stills: airs till
Postby packapoo » Wed Feb 15, 2017 3:23 am
BM - Braumeister
GF - Grainfather
Postby tasleBHC » Thu Feb 16, 2017 12:23 am
packapoo wrote:BM - Braumeister
GF - Grainfather
i looked at the BM and GF and i take it the BM is for mashing and fermenting and the GF for the distilling of wash??
tasleBHC
Stills: airs till
Postby packapoo » Thu Feb 16, 2017 2:25 am
They both do the same tasks basically. There are design differences in operation between them.
GF can be used as a still; to that end I would imagine the BM could be too and perhaps that is what Mash has recently been alluding to in his latest lot of mischief ;) .
Postby Mash » Thu Feb 16, 2017 6:13 am
Not quite but its always on the list!
Postby Casper » Thu Feb 16, 2017 7:24 pm
Easydrinker wrote:
Casper wrote:Our sweetest Irish whiskey, Jameson's, uses maize spirit which is refluxed.. Tullamore Dew is another example.
Why don't you? I read it on the back of a bottle and on their website. It even tells you the fermentation temperature and period... they don't do secondary fermentation it's a 3-4 day ferment at 24°C. A barley potstill is then blended with a grain (aka corn) refluxed at 96% after they are both aged
Casper
Postby Casper » Thu Feb 16, 2017 9:04 pm
Still maturing wrote:I would like to add a good bit of sweetness to my whisky. I know bourbon gets its sweetness from the corn, but I like the taste of a good single malt. If I was to throw a spanner in the works and move into a hybrid malt/corn mash, would this give me a sweeter end product? Or would it change the structure too much?
A single malt with a touch of bourbon, without adding additional additives would be my goal >:D
Thanks
Of course oak gives colour, vanilla, sugars, and also carbon cleaning. But you are right, maize after 3years on oak has only sweetness, none of the complexity added by rye and barley. Wheat, barley or rye in turn has less carbs or sugars than maize.
Starch is extracted from barley at a much lower temperature than from corn. Corn has far more carbs, would be too gelatinous (stodgy porridge) so the maize is kibbled instead to keep it porous but needs boiled to extract. Corn may also be fermented on grain, but not with barley or any soft grain.
Barley adjunct and barley malt are not rested at the same temperatures either. But I can't see there is a difference in taste between 100% malt and 200% barley activated by some % sprouted barley. Malted barley has more than enough enzymes to convert ten times as much adjunct grain starch fully to sugar. Doesn't matter whether it's corn, rye, wheat, or barley adjunct.
Have a gander at the buffalo trace site. They mash each grain separately, then blend the run-offs in the fermenter. They then sparge into their next mash, not to fermentation
So
Heat each grain, including the malt, to its own separate gel temp, It may help yo trownin some sacrificial malt to maize for a brief saccharification rest on the way up to make it thinner. Then blend all the run offs into your fermenter.
They say that maize loses all its flavours after 3 years ageing. All that's left is sweetness.
Casper
