Page 2 of 2
Re: Plum Brandy
PostPosted: Fri Jun 17, 2016 7:18 am
Myles wrote:
Mash wrote:Good one Myles. Why the starter?
I now use starters with all my fruit fermentations. Basically I prepare the wash/mash in the fermenter. Strain off some liquid and dilute it. I start the yeast in a gallon demijon.
It gives the pectic enzyme 24 hours to work on the fruit before the yeast is added, and in that same time period I get a really vigorously fermenting 6 pint batch.
My fermenters are usually cool so doing it with a starter (warmer) gives a faster start to the fermentation after the starter is added so there is less chance of infection.
If you just pitch yeast into the fruit it can take a bit longer to get going.
Got it. Thats good thinking. I solved the problem with electric blankets and no sulphite.
Re: Plum Brandy
PostPosted: Fri Jun 17, 2016 4:56 pm
by gaza the instructor
Getting more enthused by each new
piece of info.
Re: Plum Brandy
PostPosted: Fri Jun 17, 2016 10:49 pm
I found the problem with cooler ferments is that the yeast are not giving their best.
Electric blankets really make a difference. Cheap as chips and certainly controllable enough with the regular stat.
Allow 1 single per 50 liters :)
Re: Plum Brandy
PostPosted: Sat Jun 18, 2016 5:57 am
I use these Mash. Keep a 25ltr wash steady
between 22 &24 C.
http://www.home-brew-online.com/equipme ... -pad-p2435
Re: Plum Brandy
PostPosted: Sat Jun 18, 2016 6:37 am
They are good 'cos you can add insulation on top to control the temp.
I use electric blankets for my big fermenters.
Re: Plumb Brandy
PostPosted: Sat Jun 18, 2016 8:32 pm
by packapoo
Mash wrote:They are good 'cos you can add insulation on top to control the temp.
Gotta consider this.
What do you do Mash? Underneath or wrap around?
Re: Plum Brandy
PostPosted: Sun Jun 19, 2016 12:48 am
nah,sorry,
Electric blankets ,charity shops, leaking old ladies.
I don't want to go there ;)
Re: Plum Brandy
PostPosted: Sun Jun 19, 2016 7:09 am
Robert what have you done!!
"Leaky old ladies"
LOL will never be the same again :o
Re: Plum Brandy
PostPosted: Sun Jun 19, 2016 7:17 am
packapoo wrote:What do you do Mash? Underneath or wrap around?
Easiest way I have found is the wrap them round. Camp mat type foam over the top and then a bungee top and bottom to secure.
Use top seeing to get going. Once warm enough gradually decrease as the yeast starts making it own heat. I don't insulate / heat the bottom the concrete gives me a bit of a buffer. Works a treat on my 500's fermentation through in 7 to 10 days at a steady 25c.
Re: Plum Brandy
PostPosted: Sun Jun 19, 2016 9:39 am
by Phantom
According to some stuff I've read, plums and the waxy skin thing is sorted by 24 hours in a weak soda ash solution........
Re: Plum Brandy
PostPosted: Sun Jun 19, 2016 11:10 am
Good shout.
I is also safe to fermentation & end product even if a little remains after rinsing. Often used as barrel cleaner.
Never thought of washing my plums with it.
Re: Plum Brandy
PostPosted: Sun Jun 19, 2016 1:13 pm
by Benoit
If you boys want to wash your plums with soda ash then feel free, when the hair falls out & the skin gets itchy don't say I didn't warn you :D
Re: Plum Brandy
PostPosted: Sun Jun 19, 2016 6:46 pm
Very cruel Benoit,suppose you would make 'em
use Izal for a month as well ;D
Re: Plum Brandy
PostPosted: Sun Jun 19, 2016 11:05 pm
We are almost back to leaky old ladies....
Re: Plum Brandy
PostPosted: Mon Jun 20, 2016 4:00 am
by packapoo
Thanks for that Mash.....filed for further.
