Infusion using the Still Spirits basket and muslin
Different methods and recipes
Postby JohnD » Sun Aug 20, 2017 8:06 am
Hi,
Have been lurking for a while. I have got to the point where I did a Gin run with 1L of 40% and 1 L of water and then:-
12G Juniper
6G Coriander (seeds)
1/2 a Tangerine peel
(no Angelica)
This was ground lightly in with a pestle and mortar and then wrapped in a little bit of muslin - this was quite a tight 'package' to get it into the Still Spirits Gin basket.
What resulted after 2 hours was about 700Ml at 50% BUT it was a 'coriander' Gin - not much smell or taste of Juniper! Diluted down to 41% its quite drinkable but not really 'gin' - I have called it 'Questionable".
So do I try just placing the botanicals into the basket? Or just reduce the coriander?
I do worry about small stuff going up the 'stack' which is why I used the muslin.
:o
JohnD
Re: Infusion using the Still Spirits basket and muslin
Postby hampk » Sun Aug 20, 2017 6:10 pm
I can't comment on the StilSpirots basket as I use a Sputnik (colander on legs, a great invention by Mash) but I'd be surprised if you got bits up the stack, as you put it. I'd definitely lose the muslin, I think.
I'd say your proportions of juniper and coriander are about right, but I've started using less per litre; I did a run this morning with 9g juniper and 4.5g coriander. I think that's personal taste though - my earlier gains were very juniper heavy.
Keep playing, keep notes. If you do hit a great mix, you'll want to be able to repeat it!
Hampk
hampk
Stills: Airstill
Postby JohnD » Sun Aug 20, 2017 6:15 pm
Cheers - I'm going to have another go, without the 'bag' !
JohnD
Postby gaza the instructor » Sun Aug 20, 2017 6:30 pm
#1 Hampk on loosing the muslin.
John D I have one of those Gin Baskets (sorry guys had to try)
They are ok for small amounts, put the bots in loose the flavours
carry thru well, but overload the basket and I did have a small
amount of bots in the final product.
Result is I use my Sputnik much better.
Look up on this site and build one, even a numb numb like me managed.
Looking for the right colander is the difficult bit. It needs to fit
quite snug in the AS I think the measurement was 7.5 inches diameter.
The correct size of these will do, cut off handles and some legs.
http://www.ebay.co.uk/itm/Stainless-Ste ... 0005.m1851
Last edited by gaza the instructor on Sun Aug 20, 2017 6:43 pm, edited 1 time in total.
Postby JohnD » Sun Aug 20, 2017 6:39 pm
Cheers - I have been looking at those - I'm going to have a go with loose botanical and then decide.
JohnD
Postby gaza the instructor » Sun Aug 20, 2017 6:49 pm
No problem JohnD Ebay is a wonderful place.
I think I used 3mm studding with nuts and washers to suit.
Again all on Ebay. Cost me about £10. Gives me room for a
3 liter charge. :) :)
Postby Easydrinker » Sun Aug 20, 2017 8:51 pm
Not all juniper berries are created equal.
It may be those to blame?
Postby H12rpo » Sun Aug 20, 2017 9:32 pm
Just chiming in to say Sainsbury's do juniper berries dried in their spices range.....a 30 gram jar for a quid .....can't be bad
H12rpo
Postby gaza the instructor » Mon Aug 21, 2017 6:51 am
Postby H12rpo » Mon Aug 21, 2017 10:31 am
Something wrong with your maths Gaza
H12rpo
Postby Toper » Mon Aug 21, 2017 12:30 pm
T
Toper
Stills: Copper Pot Still
Postby gaza the instructor » Mon Aug 21, 2017 2:16 pm
H12rpo wrote:Something wrong with your maths Gaza
Don't think so mate 250g for £5 delivered
Postby gaza the instructor » Mon Aug 21, 2017 2:20 pm
Thats a good price Toper don't know about you but
I normally order 1kg at a time. First for price
second if its a really good batch I have enough
to last a while.
Postby Toper » Mon Aug 21, 2017 2:31 pm
I too buy by the Kg.
If you have a regular Gin run then nothing goes to waste and the saving is tremendous.
T
Toper
