Postby Robbo12 » Fri Jan 12, 2018 12:54 am
Well my first ever run it was the classic 8 turbo wash 8 kg granulated sugar 25 litres wash fermentation done in 5 days,put through my t500 turbo still ,it came out at 93% and got I'd say about 4.5 litres of alcohol my only problem i had was trying to keep temp between 50 and 56 °¢ one question I'd like to ask how much water do i need to water it down to 40% ? Thank I've got the bug now planning my next one .
Robbo12
Stills: T500/ Airstill
Postby Brewhunter » Fri Jan 12, 2018 6:34 am
8kg in 25ltrs is way too much, aim for around 5kg and you'll get a much better tasting product ;)
If you are saying it's 93% then you must be using an alchometer so just use that to guide while diluting.
Brewhunter
Stills: T500 + Airstill
Postby Robbo12 » Fri Jan 12, 2018 7:46 am
Ok thanks will do as it's my first you live and learn.
Robbo12
Postby Klunk » Fri Jan 12, 2018 1:15 pm
Hi Robbo.
In answer to your question, I use an free online distilling calculator. A good one can be found here:
https://www.hillbillystills.com/distilling-calculators/
I have found it pretty bang on when it comes to diluting/blending etc
+1 with what Brewhunter said as well. 8kg's is way way too much for 25ltrs. 4-5kg should suffice with a good nutrient. ;)
If I wanted patience, i'd have trained to be a doctor.
Klunk
Stills: T500 & Airstill
Postby H12rpo » Fri Jan 12, 2018 6:30 pm
Anyone measured what SG 4kg and 5kg of sugar is in a 25 litre wash ? I know there’s a calculator for that somewhere but I can’t find it
H12rpo
Postby jonx69 » Fri Jan 12, 2018 7:14 pm
H12rpo wrote:Anyone measured what SG 4kg and 5kg of sugar is in a 25 litre wash ? I know there’s a calculator for that somewhere but I can’t find it
http://homedistiller.org/sugar/wash-sugar/sg
jonx69
Postby Leatherman » Fri Jan 19, 2018 11:29 am
JD chips arrived. Looking forward to try. Just wanted to ask how much of it you usualy use? I am thinking to add 50g for 5 litres around 45abv? Does it sound good? Maybe more? What would be your advice? I understand that it is very much personal taste option, but general guidline would be very helpfull. Thanks a lot :)
Leatherman
Postby Easydrinker » Fri Jan 19, 2018 10:26 pm
Your proposal sounds good.
I use a different wood.
Start somewhere and learn.
Postby Mash » Sat Jan 20, 2018 5:42 am
Sounds a bit light. For nuking use 100g per litre.
Postby Myles » Sat Jan 20, 2018 8:25 am
You can also use the general guide that works reasonably well.
1 pound of grain in 1 gallon = 3% ABV
1 pound of sugar in 1 gallon = 6% ABV
Postby Pyro » Sun Jan 21, 2018 10:17 am
The past 2 days have been a bit hectic, 2 runs on the AS one day and one on the other, I normally manage 1 run a day. I rotated my 3 brewing barrels, 1 at wart, one at clearing and one to AS.
Also made up 2 X 1Lt Sloe Gin Liquor, 1Lt Blueberry Vodka Liquor and 1 of Plum Brandy Liquor, all are now in the dark cupboard. I have a spirit run underway on the AS at the moment.
Pyro
Stills: Twin Airstills,
Postby gaza the instructor » Sun Jan 21, 2018 1:40 pm
As for tables etc...
These might come in handy for anyone who is interested.
http://homedistiller.org/distill/dilute/calc
Postby Easydrinker » Sun Jan 21, 2018 11:24 pm
Pyro, thank's for the Blueberry mention, had missed that that one, will give it a go, shouldn't need extra sugar.
Last years Bullace, with added sugar is sublime!
Postby Pyro » Mon Jan 22, 2018 8:30 am
I use 1/2 Lb of sugar in 1 Lt of spirit in all my fruit liqueurs, occasionally I have to up the sugar, but not very often. For vodka I use neutral spirit and it comes out great.
Normally I put a pack of cut up fruit from the supermarket in a 2Lt Kilner type jar, add 1/2Lb sugar and 1Lt spirit, shake until the sugar dissolves, then into a dark cupboard for some months, give it a shake occasionally, and that's it.
Pyro
Postby Myles » Mon Jan 22, 2018 12:05 pm
Our goto standard is sloe brandy. We usually have this lying around.
In a 1 gallon demijon
3 lbs of sloes (freeze them and put them in the demijon frozen for less mess)
12 ounces of sugar
3 litres of Spanish Brandy
Leave 3 month to 1 year on the fruit.
Users browsing this forum: Easydrinker, Mash, Toper and 1 guest
In total there are 4 users online :: 3 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
