Altering a t500?
Info specific to the T500
Re: Altering a t500?
Postby Runningman » Tue Sep 25, 2012 10:19 pm
Hey John try the following for copper. Very reasonable indeed. Its the cheapest Ive seen it.
Regards
Runningman
jtmplumbing.co.uk
Runningman
Stills: 4Plate Bubble Cap
Postby YHB » Wed Sep 26, 2012 2:07 am
Good Find - Those prices are CHEAP
thanks for the link
Postby John51 » Wed Sep 26, 2012 11:07 am
well cheap!
Thanks.
John51
Postby chubby_78 » Mon Jan 14, 2013 2:36 pm
hi iv just got a few question about the 2" ferrules
do they fit the 54mm
and is it thick enough to use a tap and die set on ?
chubby_78
Postby YHB » Mon Jan 14, 2013 4:53 pm
Chubby,
Sorry, but I have completely lost the plot, which particular "ferrules" are you trying to put a thread on? male or female thread? and why?
Toodlepip
Brian
Postby chubby_78 » Mon Jan 14, 2013 6:06 pm
sorry i did it again and didnt explain my self again.
if you look at the first page of this topic there is a post ware the person shows you how to attach a column to a t500 boiler
with a copper column but im just making sure they ware on about using a 54mm column as it's 2" ferrules and dint want to order it and it not fit .m
chubby_78
Postby YHB » Mon Jan 14, 2013 6:27 pm
Chubby,
There are two connectors shown. The one I make with a brass cap, and the one Mr Cat was making with 1.1/2" to 2" stainless adapter.
Both use a 1.1/2" BSPP thread to connect to the T500 lid to match the threaded fitting supplied with the T500.
There is no need to thread anything. The ferrules that Mr Cat is using are for quick release Clover Clamps to allow different heads to be changed easily.
Brian
Postby chubby_78 » Mon Jan 14, 2013 6:33 pm
excellent so i did read it right they do fit the 54mm column
just wasnt sure as it said 2"
i was going to use the ferrules that mr cat had shown use .and tap it just to save on parts
chubby_78
Postby MrCat » Mon Jan 14, 2013 8:24 pm
Although it's a 2" BSPP thread it's not 2". It's larger. A 2" BSPP pipe has a diameter of 59mm so a 2" pipe rattles around the inside of the coupler.
Shown in that picture is a 54mm end feed coupler which has a slightly larger outer diameter. It is still too small to tap and screw in but it is close enough to braze. It is pretty big though and is going to sink a lot of heat so it's the last fitting I'm going to braze.
hope that helps.
MrCat
Postby chubby_78 » Tue Jan 15, 2013 12:03 pm
hi i was on about taping this
http://www.zx55.com/shopexd.asp?id=4229
the i could try and find something to screw into it
and it would just be like the fitting on the t500
chubby_78
Postby Magnu420 » Tue Jan 15, 2013 2:24 pm
its gonna take some tapping if its stainless steel
you might have to get it machined
Magnu420
Stills: Airstill + half boka
Postby MrCat » Tue Jan 15, 2013 10:35 pm
chubby_78 wrote:hi I was on about tapping this
Then I could try and find something to screw into it and it would just be like the fitting on the t500
You could cut a 1.5" BSPP thread in it. The internal diameter of that part is 47.6mm and the 'major diameter on a 1.5" BSPP thread is 47.8mm. The thread w0uldn't be that deep in the fitting (only .2mm) but it might be enough to grip the nut on a T500 boiler - which is a 1.5" BSPP thread. They aren't that expensive so it's worth a try - but anyone that can cut that thread into a Stainless steel fitting could also probably tig weld the flange to a a 1.5" BSPP nipple which would be quicker and most likely cheaper.
Just something to think about.
MrCat
Postby Capt-Cudellez » Tue Jan 15, 2013 11:50 pm
MrCat wrote:You could cut a 1.5" BSPP thread in it. The internal diameter of that part is 47.6mm and the 'major diameter on a 1.5" BSPP thread is 47.8mm. The thread w0uldn't be that deep in the fitting (only .2mm) but it might be enough to grip the nut on a T500 boiler - which is a 1.5" BSPP thread. They aren't that expensive so it's worth a try - but anyone that can cut that thread into a Stainless steel fitting could also probably tig weld the flange to a a 1.5" BSPP nipple which would be quicker and most likely cheaper.
that works Mr Cat.
this riser was just a 1.5 BSPP half socket welded onto 2" pipe with a triclamp at the other end, worked fine with the T500 nut.
Postby edwatters » Mon Apr 22, 2013 1:15 pm
Everyone is talking about converting a t500 but do you have to use a controller on it afterwards?
edwatters
Postby Ian3266 » Sun Apr 28, 2013 12:26 pm
Hi Runningman
What Im about to say is not and should not be taken as a comment on or even referring to JTM. I have however bought many seemingly very cheap fittings from some UK suppliers . Some have been ok'ish (well useable anyway) many were only fit for the bin, the quality being that bad. Im talking about severe pitting of the copper and the ID of end feed fittings being way out of spec.
If something is too cheap there is generally a good reason why.
Ian3266
Stills: 50ltr VM & pot
Return to T500
