brew pump
brew pump
Postby Almanac » Fri Dec 20, 2013 7:59 pm
Brouwland are promoting a new pump (Novax stainless steel electric pump) for pumping wash/mash up to 95oC and it can pump both ways ;D Going to have a look at that in the new year ;)
Re: brew pump
Postby optic » Fri Dec 20, 2013 8:24 pm
Certainly looks like a nice piece of kit, as a suggestion how about trying one of these http://shop.solarproject.co.uk/Solar-Pr ... s-c-2.html they really are fantastic little pumps and as cheap as chips. I use them all the time brewing my Ales to recirculate and pump Wort from the Mash Tun to the boiler and another one to pump the boiling Wort through a plate heat exchanger into the FV.
optic
Stills: Super Reflux
Re: brew pump
Postby Almanac » Sat Dec 21, 2013 9:06 am
Optic, you're a genius ;) seriously! You've just solved two problems I've been trying to find a cost effective solution for. Pump and power adaptor ordered and site bookmarked.
You've just made my Christmas ;)
Re: brew pump
Postby optic » Sat Dec 21, 2013 4:33 pm
No problem mate, shame you've already ordered a power supply I use along with a lot of other AG brewers a Tattoo PSU from ebay for about £10, really makes controlling the speed of the pump a doddle
optic
Re: brew pump
Postby Phantom » Sat Dec 21, 2013 6:58 pm
Aidans not the only one in the market for pumping ability optic.......
I need one to supply my condenser, plus screwfix seem to have one for 65 quid that says it will do a pump pressure of 3.6 bar so it will do fine for my RO filter.....
Plus there's a place on fleabay that does re-used plastic barrels, so I should be able to sort out rainwater recycling and management for a couple of hundred quid.......
Which isn't too bad IMO. I could pick up a 1000 litre IBC, but they're standard pallet size (1000x1200mm) and I haven't got space for that so rather than getting one of the rarer 1200x800 sized ones, 4 x 225 litre barrels is a better option......
Shame it won't get here before crimbo.......
Re: brew pump
Postby Almanac » Sat Dec 21, 2013 7:57 pm
optic wrote:No problem mate, shame you've already ordered a power supply I use along with a lot of other AG brewers a Tattoo PSU from ebay for about £10, really makes controlling the speed of the pump a doddle
Have you got a link for that and I'll have a look anyway. I have placed the order but I'm calling them on Monday to amend it to include a second pump as a backup.
Re: brew pump
Postby optic » Sat Dec 21, 2013 9:28 pm
I'm posting from my phone so cant add a link, just search tattoo power supply on ebay and its the one for £7.99 on the first page.
optic
Re: brew pump
Postby Admiral Toad » Wed Feb 18, 2015 11:06 am
A question for Optic
can't seem to find the link to the pump that you recommend
have you any other details or a name for the piece of kit or a new link
Admiral Toad
Stills: pothead, BP column
Re: brew pump
Postby Mash » Wed Feb 18, 2015 1:29 pm
Yeah - got me going tooooo
IS it this one?
http://shop.solarproject.co.uk/catalog/ ... 8b06328c28
Re: brew pump
Postby Icefever » Wed Feb 18, 2015 2:23 pm
Geez...they've gone up in price...I payed about £12/£13 for mine a year or so. :o
What about this one Here and it's ok for hot water up to 100c for £12.28...only thing is you have to order from China...and their on their holls now. :-\
edit..
Hold your horses this ones in Glasgow £11.99 also good for 100c.
Re: brew pump
Postby Mash » Wed Feb 18, 2015 3:01 pm
The glasgow ones didn;t float my boat - so I have floated a couple back from China.
I used to use whale submersibles 12v be they a £26 now .......
Re: brew pump
Postby Almanac » Wed Feb 18, 2015 7:07 pm
@Mashy. The ones from the Solar Project are the ones I use. Never a single problem and really quiet too. ;)
AM Image
Re: brew pump
Postby Mash » Wed Feb 18, 2015 7:24 pm
AM. Yeah. They look like the Chinese ones. Thanks
Re: brew pump
Postby Admiral Toad » Fri Feb 20, 2015 8:49 am
Thanks guys the Chinese one looks ideal plus I'm in no great rush
Admiral Toad
Re: brew pump
Postby vino-tinto » Fri Feb 20, 2015 5:16 pm
If you used one of these pumps, how big a water tank would you need to do a 25L wash in a LM still with a 2KW boiler so as not to need a cold water infusion to keep the temp down, that's instead of using a mains supply via a control valve. ???
vino-tinto
