Page 2 of 2
Re: Heavily Toasted Oak Chips
PostPosted: Fri Nov 11, 2016 11:27 pm
by gaza the instructor
0127frey.
On the neuking front.
I put 800ml best 40% neutral and 80g
JD chips in a jar.
Neuked once a day for 3 days.
Sealed after each neuk(kilner Jar).
Filtered into bottle mate its good :)
PostPosted: Mon Mar 27, 2017 10:07 am
by Leatherman
Hello everyone.
So I was thinking when you mix neutral with oak chips. And get final product. Can it be called wisky, or if probuably no. What would be the most acurate name for it?
PostPosted: Mon Mar 27, 2017 7:17 pm
by packapoo
Perhaps if you prefaced it with 'faux' you could give it a bit f class.
(Only a bit tho' ;) )
PostPosted: Mon Mar 27, 2017 7:56 pm
by Leatherman
At this point I must admit that my English is broken :D with a help of wikipedia I managed to understand half of your answer :D , but second half with f part. I did my best, but sorry, no chance. :)
PostPosted: Mon Mar 27, 2017 9:07 pm
My friend, I feel the need to answer several of your posts.
I will start with this one.
"Faux", French for false.
An oak flavoured neutral will not taste like a whiskey, but for some is close enough.
The second part above, you were confused by a TYPO.
It should have read, you could give it a bit of class.
The whole post being an idiosyncratic use of the English language that is slowly learned.
HTH
PostPosted: Tue Mar 28, 2017 7:50 pm
by packapoo
domasj wrote:At this point I must admit that my English is broken :D with a help of wikipedia I managed to understand half of your answer :D , but second half with f part. I did my best, but sorry, no chance. :)
Apologies domasj - I had not picked up on your struggle with English; did not intend to send you off on a hunt for understanding.
The upside is tho', it's all learning :D
Otherwise, what Easydrinker said. The spot of finger trouble got away from me before I realised. :o
