Fermenting Stripper Cabinet
This could be the most compact and quickest Air still setup. This was inspired by my trash can idea. viewtopic.php?f=2&t=4243
Instead of using a fridge as a fermenting cabinet - use a freezer !!
1. Ferment in the freezer - turned off - with an electric blanket / heating band as a heat source. Use a youngs wide mouth fermenter. Get carried away and fit an STC if you want to control the heating ONLY.
2. Once the ferment is finished. Remove the electric blanket / turn off the heating. Turn the freezer on for 2-3 day until solid. This is doing the work of 5 strip runs !!
3. Once frozen, remove from the fermenter and invert over a bucket. The bucket will collect 30% low wine. Leave what is left outside to thaw and then tip it away.
4. The contents of the bucket will be about 10/12 litres (2.5 Air Still runs) to get about 4.5 liters of good clean neutral spirit. You could keep the half in a scrumpy bottle - ready to make up a full run next time.
With a sputnik you could go straight to gin.
Once done you can store everything is the freezer so SWMBO is happy smiley. You could use a under counter freezer in the kitchen even (of is that as step tooooo far
) or the garage ?
This is the sort of freezer I was thinking .....
http://ao.com/pla/ZFG06400WA-Zanussi-Un ... 0wod2AsEhg
Edit:
This assumes there is no need for cooling during fermentation at 22-30c..... apart from one day in August the UK doesn't get hot enough in the first place.
) or the garage ?This is the sort of freezer I was thinking .....
Edit:
