Tea urn boiler
Tea urn boiler
Postby StarkBlood80 » Wed Jan 24, 2018 10:59 am
Morning
Could anyone tell me if this would make a suitable boiler if the thermostat could be bypassed?
https://www.homeshopcatalogue.co.uk/cat ... elled=true
Thanks
Chris
StarkBlood80
Re: Tea urn boiler
Postby Icefever » Wed Jan 24, 2018 2:09 pm
In a word "Yes"........but.....the problems you will have to sort out will be the seal around the boiler body & lid, clamps you get off the Bay.
Then the lid may not be strong enough to carry the weight of the column that you have to build. You could strengthen the lid, by adding a plate on the inside but this means more work for you.
The element is big enough, I would run it through a controller, and yes you would have to bypass the thermo.
Re: Tea urn boiler
Postby StarkBlood80 » Wed Jan 24, 2018 2:33 pm
I don’t mind doing a bit of modding especially as these urns can be found a lot cheaper than a keg boiler.
StarkBlood80
Re: Tea urn boiler
Postby Mash » Wed Jan 24, 2018 2:48 pm
Yes. Wire the stat out and use one of these..
https://www.ebay.co.uk/itm/AC-220V-4000 ... 2749.l2649
Re: Tea urn boiler
Postby Icefever » Wed Jan 24, 2018 2:50 pm
Are you on commission???????? :D :D :D
Re: Tea urn boiler
Postby Mash » Wed Jan 24, 2018 2:57 pm
you really would think so.
I bet the bloke thinks "sod me these are suddenly popular"
Re: Tea urn boiler
Postby StarkBlood80 » Wed Jan 24, 2018 3:13 pm
Mash wrote:Yes. Wire the stat out and use one of these..
So just wire the element directly to the power supply via the controller?
StarkBlood80
Re: Tea urn boiler
Postby Mash » Wed Jan 24, 2018 5:04 pm
yes.
Wire the element to the plug (so you bypass the stat).
Then you plug it into the controller.
And if you want better still plug that into an energy monitor.
https://www.ebay.co.uk/itm/UK-Plug-Plug ... SwRJxZiZCl
Then you can note done the numbers and btter understand and repeat.
Re: Tea urn boiler
Postby packapoo » Wed Jan 24, 2018 9:41 pm
MIGHT be worth going over to YouTube and looking for David Heath's latest video where he compares GF, BM and Bulldog.
New up today - I generally find him worthwhile viewing and very helpful/knowledgeable. Professional brewer so he know's his beans.....
Re: Tea urn boiler
Postby Mash » Thu Jan 25, 2018 8:50 am
Defo worth a watch. But jeez you need some matches to keep your eyes open.
Re: Tea urn boiler
Postby Dave » Fri Jan 26, 2018 1:03 pm
StarkBlood80 wrote:Morning
Thanks
Chris
I have one of those, got it 2nd hand, and believe me, the lid is definitely strong enough to support a column. I just use mine as a sort of mash tun at the moment, but I'm sure it would make a great boiler for a still in the future. For a seal, I looked at PTFE tubing. The lid is a nice tight fit into the body and should be quite easily sealed.
Dave
Re: Tea urn boiler
Postby StarkBlood80 » Sat Jan 27, 2018 8:24 pm
Well I’ve scored a nearly new 35l buffalo boiler. Let the fun begin
StarkBlood80
Re: Tea urn boiler
Postby Mash » Sun Jan 28, 2018 7:05 am
Nice one. Keep us posted.
Re: Tea urn boiler
Postby Icefever » Mon Jan 29, 2018 7:28 am
Silicone edging strip, take a look here, I've used it works for me.
https://www.polymax.co.uk/silicone/edgi ... ranslucent
Re: Tea urn boiler
Postby StarkBlood80 » Mon Jan 29, 2018 10:18 am
Icefever wrote:Silicone edging strip, take a look here, I've used it works for me.
Could work but the lid is already a decent fit so I think a few wraps of PTFE and a few toggle latches should do the job. I did notice the lid has a little vent in it which will need sealing.
StarkBlood80
