Racking
Racking
Postby BundyRed » Mon May 17, 2010 5:04 am
What would you guys say is the best method to rack from fermenter to fermenter and then to the still.
I have tried pouring and siphon (me sucking on the end of a hose). I have tried the jiggers for fuel in my ride on, but never had much success with them.
I have a spare inline 12v pump that I was thinking of trying next.
BundyRed
Racking
Postby Crusty » Mon May 17, 2010 7:42 am
Hi BR,
I just set my primary fermenter up on a couple of milk crates & gravity siphon to the other fermenter on the floor.
Lift it up where the first fermenter was & do the same later to the still.
Brian
Crusty
Racking
Postby BundyRed » Mon May 17, 2010 8:28 am
I don\'t have a tap in my fermenter but there is a bung in there, so I will have to put one in. I take it the sediment usually below this point.
BundyRed
Racking
Postby marc83 » Mon May 17, 2010 11:28 am
I just take it out from the tap.it has usually been sitting for a few days after degassing before i rack into another container where i add the clearing then and let sit for a few days.
After degassing it though,i sit the fermenter on an inch thick plank of wood,so it is leaning,just so most of the sediment tends to drop towards the rear,as far from the tap as possible.It lets me take as much of the clear wash as possible.
marc83
Racking
Postby Jimmy » Mon May 17, 2010 8:19 pm
I have a racking cane with a small cup type part on the end which avoids disturbing the sediment - it fits nicely through the bung in the lid of my fermenters and by placing these onto a Black and Decker style workmate I use gravity to siphon off. Seems to work OK, if I had a fermenter with a tap I would probably prefer that method but it does the job.
Jimmy
Site Owner
Site Owner
Racking
Postby marc83 » Tue May 18, 2010 12:18 am
If you set the fermenter up somewhere before degassing and adding clear where you wont have to disturb it again,you will have a better chance of not getting any sediment into your still.When i degas it usually sits at the end of the desk it is on until i clean it out when im finished,it doesnt move from there.
marc83
Racking
Postby BundyRed » Tue May 18, 2010 3:47 am
Thanks for the replies. I was thinking along the same lines as to have the fermenter tilted back and allow to settle before racking off. My triple distilled is done, so I will add the clear tonight. I don\'t have the second fermenter yet, so I will just rack off into the still and back into the fermenter once I have cleaned it out. This will help to degas it anyway. Lucky the T500 has a tap on it.
BundyRed
