ideas for T500 pot still mods??
Postby jack_man » Tue Jun 12, 2012 9:56 pm
i recently started in this hobby.. i bought the t500 after failing at my own build.. ive seen people modify their t500 i was wondering if you can add a regular worm condenser and do whiskey runs.. rum exc.. any input would be much appreciated!!
jack_man
Re: ideas for T500 pot still mods??
doubling keg??
jack_man
Postby Jimmy » Tue Jun 12, 2012 10:27 pm
Check the thread 'Copper Column' in the T500 section, good place to start! :)
viewtopic.php?f=12&t=1049
Jimmy
Site Owner
Site Owner
Postby YHB » Wed Jun 13, 2012 6:51 am
Jack,
Welcome to the forum.
I recently went through the pain barrier of finding a suitable connector for the T500 and ended up making a couple of Pot Heads like this.
This one has a lieberg condenser but once you have the column sorted you can add whatever condenser you like, including the worm that you suggest.
If you want talking through a build / what parts to use or even some practical help then just let me know.
Toodlepip
Brian
Postby Almanac » Wed Jun 13, 2012 10:06 am
That is one deep deep parrot Brian.
I had intended to copy your cups but haven't gotten around to it yet. I've been too busy trying to get my VM and other bits finished and making more washes for my pot. Busy, busy, busy, ;D ;D ;D
Postby YHB » Wed Jun 13, 2012 11:38 am
Aidan,
It's not a deep parrot at all - the bottom half of the vertical leg is just a support to get the parrot's beak at the correct elevation to suit a demijohn.
I cut a 20mm disc and soldered it into the spirit chamber of the parrot just below the inlet pipe. The bottom half of the pipe is always empty.
Postby jack_man » Wed Jun 13, 2012 6:49 pm
YHB,
thanks for the input that is an awesome rig... maybe a parts list if you could! how did you connect the column to the lid of the turbo!! thanks again
cheeers
Jack
jack_man
Postby Admiral Toad » Wed Jun 13, 2012 7:11 pm
Jack
Being the recipient of Brians first T500 pothead it's spot on mate !
AT. ;D
Admiral Toad
Stills: pothead, BP column
Postby jack_man » Wed Jun 13, 2012 7:22 pm
very nice.. well i hope to get a list of materials so i can pursue my own leibig.. I dont suppose there is anyway to add a doubling keg or (thump keg) to that type of condenser is there?
jack_man
Postby MrCat » Wed Jun 13, 2012 9:27 pm
strangely enough that is exactly what I asked. YHB very cleverly made them with a compression joint between the pot head and the condenser (in the 'horizontal' section so yes you could very easily fit a thumper in (as I intend to do)
MrCat
Postby jack_man » Wed Jun 13, 2012 11:52 pm
Is there anybody here willing to build one of these contraptions and ship it to me for a fair price?? my soldiering skill are less then up to par and I hardly ever have time to build one!!
Thanks
Jack
jack_man
Postby Capt-Cudellez » Thu Jun 14, 2012 4:48 pm
jack_man wrote:my soldiering skill are less then up to par and I hardly ever have time to build one!!
My soldering skills are far from good also - but I wise man once told me, if you don't have time to build a still, then you don't have time to run one either. ;D
Postby jack_man » Thu Jun 14, 2012 10:49 pm
im sure i can find time!! here in a month or so i get a paid vacation!! Hmmm wonder what ill be doing with my time...
jack_man
Postby nwshiner » Mon Feb 04, 2013 7:52 pm
YHB,
it seems that you are a profound copper master and people look to you for advice. how hard would it be to hook something like this to a 15.5 gallon keg type still? thanks in advance for your time and help!
nwshiner
Postby Keystone » Tue Feb 05, 2013 1:06 am
nwshiner wrote:YHB,
What would you connect to the keg? The T500 condenser or a pot still head? If the latter, then a 2" triclamp and gasket would work in combination with an easy flange or 2" ferrule.
Keystone
