Nuclear Whiskey / Nuclear Rum and Spirits Rapid Ageing
Different methods and recipes
Re: Nuclear Whiskey / Nuclear Rum and Spirits Rapid Ageing
Postby H12rpo » Mon Aug 21, 2017 5:48 pm
In answer to Roberts earlier question....how far will I go in pursuit of a good single malt.... I think that's my aim. I'm having fun experimenting with neutral using essences and added ' notes' and nuking with oak dominoes etc whilst I complete my pot head build.
My intention is to do the malted barley mash thing but all in good time.
H12rpo
Postby Easydrinker » Mon Aug 21, 2017 10:45 pm
Do go all the way, when you are ready ;)
You won't be sorry.
Postby gaza the instructor » Sat Aug 04, 2018 7:34 pm
Is this the new way to rapid age spirits.
https://www.youtube.com/watch?v=hgLanpdX9eE
Postby Mash » Sun Aug 05, 2018 6:07 am
Nice find. So could you do this at home then ;D ;D ;D
Postby Maker » Mon Aug 06, 2018 9:50 pm
Saw this vid a couple of weeks ago or one of the other vids from the same company, got me thinking.
I did some research years ago on impregnating wood with resin to stabalise it in temperature and moisture situations, I could see the obvious cross over here, if you had your wood in a vacuum (tee hee...!) the moisture contained in the wood would boil off at a low temp, dont quote but 35 degrees celcius rings a bell, dump the moisure from the chamber and insert spirit, the hollow fibres of the wood will receive the spirit, keep under pressure and add heat would make a nice tea.
Could it be done at home Mash, I think so, I'm only a couple of projects away from finding out and I have a vacuum pump and a chamber in stock.
As I see it there are only a few options, possitive, negative pressure and heat, got to be worth a go.
Maker
Stills: KEG
Postby Mash » Tue Aug 07, 2018 7:42 am
This is doing in a larger quantity what we do in the microwave.
I get one hell of a vacuum in my clips top jars, so much so I have to pull the seal out sideways.
Try it. You don't need a vac pump to do 3 litres. Save your pennies for a ultrasonic cleaner.... you can't do that in a miccy. ;D
Postby Maker » Tue Aug 07, 2018 10:01 pm
I have read some more in to this and it looks like they dont use a vaccuum but rather pressure.
"disruptive pressure-aging® technology".
https://www.esquire.com/food-drink/drinks/a35979/rapidly-aged-whiskey-primer/
So I guess they just use wood chip and in a big stainless barrel under pressure with a stirring paddle.
Maker
Stills: KEG
Postby Mash » Wed Aug 08, 2018 8:29 am
Hmm. Thats easier still have a workshop compressor and a pressure cooker?
Hmmm..
Hmmmmmm.
Postby Maker » Wed Aug 08, 2018 10:59 pm
That was my initial thoughts but do we even need a compressor, warming up a pressure cooker would add pressure.
I have a heat/stir device and a pressure cooker so as long as the magnet reaches through the bottom of the pressure cooker we are good to go, I'll check in the morning.
Maker
Stills: KEG
Postby Easydrinker » Thu Aug 09, 2018 12:37 am
Loving this thread.
You are talking more talk than Mash can. ;D
It's the Hmmmm's that give it away.
But big him up for posting to prove that this site is not quite dead.
Postby Mash » Thu Aug 09, 2018 5:59 am
Maker wrote:That was my initial thoughts but do we even need a compressor
Any tyre pump. Bike pump would do.
A bigger question is what pressure do we need to achieve? Pressure cookers have safety valves.
Postby Mash » Thu Aug 09, 2018 6:01 am
Easydrinker wrote:Loving this thread.
It's suffering from a bit too much sun that's all. ;D
Postby Maker » Thu Aug 09, 2018 7:15 pm
Well the pressure cooker I rummaged for has a stainless lid but an ali bottom, although coated, I take it I cant use that?
In the meanwhile I have rigged up a jar on my heater/stirrer, in a sink in case the jar cracks...
Jar contains 300ml @ 60% and 10g of fine barrel chips, heated to 50 degrees and the stirrer is set at 500rpm.
There is no added pressure, just what ever the heat adds, will it work, who knows, I set it going at 8pm so I'll have a look later.
Maker
Stills: KEG
Postby Mash » Fri Aug 10, 2018 6:14 am
Are you allergic to microwave ovens ;D ;D
Postby FullySilenced » Sun Nov 18, 2018 9:51 pm
Some people just like to reinvent the wheel...
Happy Stillin
FS
FullySilenced
Stills: 2 Still Dragon's
