Chalky residue
Chalky residue
Recently I have noticed a very fine chalky residue is settling at the bottom of my bottles after I have watered down the spirit to 40%. The spirit is totally clear at 95% in the bottle, so I assume the problem is with the tap water I use to reduce the spirit to 40%. This problem has occurred on the the last 2 spirit runs and never before.
Today I have installed a water filter system in the Brewhouse for watering down the spirit. I hope this will cure the problem but I am baffled as to why it has happened.
Any ideas guys?
Any ideas guys?
fuf - Donated to StillSmart
- Stills: T500 + SPP
Re: Chalky residue
Hi Fuf.
A similar Q ask on another forum states it maybe the " flouride chemicals" in the tap water that's used to dilute. I've also read the same thing somewhere else, so I think your assumption is correct mate.
I've read posts where the guys use distilled water or even filtered rainwater.
In fact I think it's on here somewhere about using the airstill to run off the water that's then used to water down.
Re: Chalky residue
A few of us hereabouts use a Reverse Osmosis filter to produce clean-clean water for letting down spirits to bottle strength. It definitely does remove any doubt.
You'll get very good results using something like a Britta filter to clean up your water too.
Re: Chalky residue
Re: Chalky residue
fwiw a local aquarium shop will give you upto 50l of ro water, gratis
i was up front and told em i was after it for brewing and they didnt bat an eyelid and filled up my jerrycans.. might be worth a few speculative phone calls round your area..
Fil - Experienced Distiller
Re: Chalky residue
I tried that over here in a pet shop that does a huge range in aquarium supplies. The manager looked at me like I had two heads and said "Sorry sir, I've never even heard of ...what did you call it again?
I went online and bought an RO system which I installed under my workshop sink.
Re: Chalky residue
I found this and thought of you
https://www.stilldragon.org/discussion/ ... r-proofing
Could be calcium or other minerals in the water
Re: Chalky residue
Anavrin wrote:I found this and thought of you
Re: Chalky residue
Hi fuf
Just a thought
You could proof it down to 40% and store it in a demijon for a while to allow the residue to fall out, then siphon it off if that works, at least it's safe to drink.
Just a thought
Re: Chalky residue
You could also try treating your water with gypsum to make suspended salts precipitate out before using the water for other purposes.
I have a document of water treatment for brewing stored on my main computer at home and I'll post it it here when I get home.
Re: Chalky residue
I have had enough of this residue, tried the water filter and coffee filter but the problem is still present.
So, after much
I have ordered the Essencia Carbon Filter @ £72.97 and a spare Carbon Cartridge @ £17.66 from Discount Brew. The spare is a backup for when I kill the original trying to take it apart to refill with carbon.
If this does not solve the problem
A big thank you to all of you guys for your input.
So, after much
Re: Chalky residue
You could try aidanmac's new guide to water treatment to reduce the amount of calcium in your wash water, you'll be impressed with the essencia by the way
Re: Chalky residue
The spare carbon filter maybe over kill,but I'm loving your style.
I am sure you will break into the supplied one,without problem,when the the time is right.for a re-fill.
And you will enjoy the results.
Re: Chalky residue
I used to get this problem, if you have some stronger spirit on hand add it to the container to push the ABV up to closer to 50% - give it a shake and leave it a while, if the residue goes redissolves then it probably only comes out of solution's at lower ABVs.
I bottle everything at 46% and don't have this issue any more - cant say its the same issue you have, but if your happy with the taste of your tap water, it might save you the price of a filter, and is at least worth an experiment.
Re: Chalky residue
Capt-Cudellez wrote:I used to get this problem, if you have some stronger spirit on hand add it to the container to push the ABV up to closer to 50% - give it a shake and leave it a while, if the residue goes redissolves then it probably only comes out of solution's at lower ABVs.
Thank you for that Capt. That could well be the answer! I used to bottle all at 50% but
