ebay air still
ebay air still
Postby bertybucket » Sun May 06, 2012 10:16 pm
Air still on eBay, good buy for novice?
http://item.mobileweb.ebay.co.uk/viewit ... 2901872315
bertybucket
Re: ebay air still
Postby bobnot » Wed May 09, 2012 9:35 pm
Hi
I have only just seen this this did you buy it?
Yes they are ideal for a novice i nearly made the mistake of buying an expensive still that i clearly wouldnt of known how to use properly or safely and you can make some really good stuff with the airstill.
Definitely the best place to start while you get to grips with it all.
bobnot
Stills: Airstill
Re: ebay air still
Postby Almanac » Thu May 10, 2012 8:10 am
Definitely the place to start. Even if you have the cash available to buy a bigger setup the Airstill is what I recommend to anyone that asks for advice. This is mainly because the mistakes you'll make, as you learn the nuts & bolts of this fascinating hobby, will all be little ones due to the small volume the Airstill holds.
Despite it's size, and as bobnot says, you can make some really good stuff with an Airstill. I make Bourbon and Vodka and, if I say so myself, I make bloody good stuff too, but my point is that I'm still using an Airstill.
Can I offer some advice which I proffer as a three part Golden Rule to distill by:
1 Don't try to squeeze every last %of alcohol from any wash you make;
2 An average ABV wash will be much cleaner than a high ABV turbo one;
3 In the course of following this hobby, even with just and Airstill, you'll make more alcohol than you will ever consume so don't skimp when you have to discard part of what you've made for your own safety.
Whatever you decide - enjoy it and be safe.
