copper parrot and alembic head
Hi all,
just a quick query for all you guy's with far more knowledge than me
what's the best way to clean the inside of a parrot and alembic head?
cheers
cheers
eattheliving - Experienced Distiller
Re: copper parrot and alembic head
Block the output flow tube of the parrot, make a mix of vinegar + salt + water and fill it up. Leave to stand for 1 hour and then flush it out with water, clean as a whistle.
If the head is normal copper wipe it with the same solution and wash it off when you wash the parrot.
vino-tinto - Senior Distiller
thanks vino.
the head is copper. do I flush it thru to clean it?
These days I tend to use a hot solution of Citric acid for copper cleaning, it is cheap enough, if bought in bulk and seems to work well.
Finding ways of using it on/in the twists and turns of your own copper
ware is your personal problem!
+1 on copper
thanks guy's for your help.
I went down the route of using citric acid.
worked a treat.
worked a treat.
