Hi Guys,
Noobie here with an airstill
. I've done one run of 4L of sugar wash as the instructions say with my new plaything, but it is indeed very sweet and most of all incredibly "flowery" in scent (not chemical though, whats that mean?)
I wanted to improve it now my first 25litre batch has fermented (I'm afraid I'm still on a mix of brewers and household sugar with triple distilled turbo yeast and all the carbon gimmicks etc for this brew) This
guide really is invaluable, especially as a turbostill 500 friend had concerned me about whether I needed to dilute the product from the stripping wash to avoid explosions etc (being a constant 78 degrees or whatever I guessed not particularly).
One question though, As time is a bit of an issue so I intend to literally just follow the procedure in the diagram to get something better than a single distillation. If we exclude all the jargon, why can't I just do the first distillation(s) and dilute as mentioned, then in step 2 just take off 300ml and chuck it away? After all, the maths just says there will be 6 times as much foreshots as the wash has come from the product of 6 stills and theres no mention of what you would do with the heads?
The same with the hearts. If someone else has gone to all the effort of finding out whats best with regards to tails (I was a bit unsure about the "average of 2 jars" statement and what you meant by that, do you mean in your experience it is generally 200ml that you add to the hearts?), can I not just collect 1200ml of "product" and be done?
IE for the second distillation I could just throw away the 1st 300ml, collect 1200ml and not worry about the tails OR use them to dilute my next stripping run instead of water, job done?
I know this wont make the booze "absoloutely the best it can be" for any specific wash, and I intend to do the full process in the future, but for someone who is running out of Tequila and whisky and wants to see how a full batch works with his new toy, it will at least be far better than a single run?
No criticism meant to all the hard work thats gone into this I'm just trying to cut it down to a "Dummys
guide to better than the still instructions" Alchohol in as few points as possible.
