Re: An update on my journey......
My way of thinking about this goes something like;
Running a reflux still results in the vapours stacking up in the column with the lowest temperature elements at the top.
For this description lets call the stuff at the top "heads".
During the initial part of the run the reflux action of the still will cause the heads to stack up at the top until all the heads have been removed.
If you take off the product quicker than your still is capable of stacking up the heads than you will start and pull a mixture of heads and hearts. resulting in either a larger amount of heads that need to be cut out or hearts that are "smeared" with heads. If you can reach "equilibrium" with the amount of heads being produced equal to the amount of spirits being removed then you will have a smaller amount of heads which will have been "compressed" or "compacted" and a larger amount of cleaner hearts.
If you start taking product too early then you will only have a thin layer of heads at the top of the column which is easily depleted and will result in smearing. If you leave it in 100% reflux for a longer period then you will have a larger amount of heads as a buffer and reduce the risk of smearing.
Hope that helps.
Hope that helps.
