Page 2 of 2
Re: My VM Reincarnation
PostPosted: Sat Aug 31, 2013 3:18 pm
by Myles
I use a variation (mine is offset) of this on my own column. Take the heads off as liguid through a valve, and take the hearts through the VM side.
I believe what stillton was referring to though is the combined use of a heads trap in the condenser and a packed heads column above your VM port.
If you have the height available this is probably the best solution. You don't even need to remove the heads at all. Just shift them into the column above your VM port where they cause you no trouble at all.
If you have the space I would recommend this combination as probably the easiest to use.
PostPosted: Sat Aug 31, 2013 4:24 pm
by stillton
Hi!
Myles.. you got it :-)
