Re: turbo 48
Turbo= (insert spew emote)
tpw=
tpw=
aidanmac wrote:OK! I've searched, cogitated and ruminated but I still can't figure out 'YMMV'.....go on, put me out of my misery![]()
I can't see how being busy or lazy impacts on it. I'm as lazy as homer.Phantom wrote:Well see all the criticisms etc are a little pointless aren't they.
Turbos will generally "do what it says on the tin" when the guidance/instructions are followed. Of course YMMV but they're about convenience and when it's a largish bag of yeast with the nutrients for about the £3 mark instead of the £1 or so for an easily obtained and reliable wine yeast plus the cost of nutrients etc, which can be a pain when you don't know what you're doing and by stressing the yeast its easy to get the telltale of H2S/rotten egg smell, which doesn't, by the way, magically disappear when the ferment finishes (extra nutrient and good stirring/aeration is generally needed), when you factor in the time and effort, cost of it all and so on, turbos can indeed be convenient.
Yes I have tried TPW and other basic sugar based versions, but they all produce pretty much the same result. Hence YMMV....... I just find its more about using the still carefully and not hoping that some sort of "quick" yeast is a magic bullet. Hell, turbos, TPW etc all seem to take me about 7 days to ferment, which is plenty quick enough to my mind.
Yet because I can be a lazy t**t, I might make a wash and it'll be in the bucket for 2 months before it gets run..run....just depends on whether I've got something to drink or not.......
googe wrote:Thanks for the info mate, do you do tpw with turbo yeast?. I know bugger all about turbos but have re d enough to be scares. why do you need to carbon filter?. Do you do cuts and filter the hearts, or just do a bulk distill and filter that?. A dude at work does turbos and filters and uses essence and it's way to sweet for me, that's my tastes . I did notice the heads taste in his though, even after filtering.
