Page 2 of 2
Re: Copper saddles
PostPosted: Thu Jan 18, 2018 9:42 am
by H12rpo
Cleaning the boil ceramic tooth shaped things are more difficult. I’ve tried citric and vinegar and got nowhere. Anyone have a clue?
Re: Copper saddles
PostPosted: Thu Jan 18, 2018 9:49 am
by Leatherman
Every few runs I take all saddles. Separate cupper from stainless steel ones. And soak them in cola with squized lemon over night. The give them a good wash and put them back in. Works well for me.
Re: Copper saddles
PostPosted: Thu Jan 18, 2018 9:58 am
by Brewhunter
H12rpo wrote:Cleaning the boil ceramic tooth shaped things are more difficult. I’ve tried citric and vinegar and got nowhere. Anyone have a clue?
Use them until discoloured then replace.
Re: Copper saddles
PostPosted: Thu Jan 18, 2018 1:36 pm
I use citric acid - did wonder if the industrial whisky boys do their copper or just replace then when they wear out?
Re: Copper saddles
PostPosted: Thu Jan 18, 2018 8:13 pm
Citric Acid is fairly inexpensive bought on-line, in quantity: I buy around 5Kg every year or so.
It keeps all my copper bits and pieces clean.
I soak boil pieces in it, I dissolve in water and pour through my column and condenser.
Re: Copper saddles
PostPosted: Thu Jan 18, 2018 8:31 pm
by packapoo
Storing ceramics in a jar of foreshots works for me.....
Re: Copper saddles
PostPosted: Thu Jan 18, 2018 10:41 pm
by Robbo12
I've ordered some citric acid and gonna clean the column too i don't want my next wash to be tasting chemicaly again i want a good clean wash and produce a natural wash.
Re: Copper saddles
PostPosted: Fri Jan 19, 2018 5:36 am
If you want to clean the still run it with a water/vinegar mix.
Re: Copper saddles
PostPosted: Fri Jan 19, 2018 10:16 pm
That works, but can make your eyes water ;D
Then you need to run again with just water.
Or I do. :)
