Turbo still 500 problem
I was distilling my wash & running water temp at 55-60dgs all good collecting 1400ml in 2hours then it just slowed right down collecting only 200ml over the next 3hrs, the is no leaks in hoses or seals & no visible blockages, need help please
Aussieshane - Newcomer
Re: Turbo still 500 problem
What sort of wash are you using?
What volume?
Did you measure original and final SGs?
If so, what were the numbers?
What volume?
Like GTF said we need a little more info....could be something simple like you'd taken all the likker that there was in the wash out?
Hi guys,
I got a question about that T500: the temperature you measure, is that the top temperature of your column or the cooling water outlet temp?
They say 55-60°C is the best, but ethanol boils at 78,5°C?
Dynamic - Regular
- Stills: AirStill, T500
dynamic wrote:Hi guys,
It's the water outlet temperature you need to monitor
vino-tinto - Senior Distiller
