Lentil Wash
Re: Lentil Wash
Postby Easydrinker » Sat Jan 25, 2014 3:04 am
Brian and Aidan both nailed this there I think,perfect logic,science,chemistry and biology.
Being a diehard turbo fan I currently have a lentil wash racing a vodka star and an alcotech 48,all started within minutes of each other,half packs of yeast,same sugar levels,5kg.
Using yellow split peas[As I believe Scarecrow originally did] (cos they're really cheap),not red lentils.
Looks to be neck and neck as they approach the finishing tape,although I suspect the split pea wash will come out on top as the wash cost is about £1GBP lower per bucket.
Not really an amount worth writing home about
But I did,apparently!
I know I need to get out more.
I did last night,Del Amitri in Glasgow,Brilliant.
Still buzzin'.
Re: Lentil Wash
Postby Phantom » Sat Jan 25, 2014 10:21 am
Excellent.......
The also tech 48, should (from memory), be quickest, but like with anything Rob, it often comes down to the numbers - hence I happily use vodka star and because I get away with no carbon and not fining it, it costs me the sugar, the yeast/nutrient pack and the cost of leccy/water to cool my T500, so half the price of using a full SS triple distilled wash pack(s)......
Must have a cracking at the lentil wash sometime though.......
Re: Lentil Wash
Postby mikepiet » Sun Jan 26, 2014 2:04 am
Afternoon all,
Just thought I' throw up this pic of the krausen on the lentil wash I put up last evening. Photo was taken about 12 or 13 hours after yeast was pitched. :-)
Looks like its off to a good start.
All the best,
Mike P
mikepiet
Re: Lentil Wash
Postby Icefever » Sun Jan 26, 2014 6:21 am
Yup...just the same as mine....on the first go, but 2nd time round it's a lot slower. ;)
Re: Lentil Wash
Postby Corps012588 » Thu Jan 30, 2014 4:07 pm
Ok. Another update!
This wash has been on since the 9th now and this is the current reading
What does this wash normally read when finished?
If I take a reading then pour the trial jar back in it bubbles for a couple of hours then stops again.
I'm used to the turbo washes starting to clear when they are finished, does this one do the same?
I'm just a little worried it may be screwed!
Corps012588
Re: Lentil Wash
Postby Corps012588 » Thu Jan 30, 2014 4:09 pm
Really what I'm trying to ask is is this length of time abnormal?!
Thanks in advance
Corps012588
Re: Lentil Wash
Postby Almanac » Thu Jan 30, 2014 4:47 pm
Temperature affects ferments and the lower the temp the slower it will be. The other problem with long ferments is that it gives the pH more chance of dropping below 3 and putting the yeast cells to sleep.
Can I ask, how much lentils did you use with the 11kgs of sugar?
Re: Lentil Wash
Postby Corps012588 » Thu Jan 30, 2014 4:52 pm
Hi Aidan
Went with 500g as guidance from yourself for a single gen.
It's been at 22/24c on my temp strip since day get go.
Does this sound ok buddy?
Corps012588
Re: Lentil Wash
Postby Icefever » Thu Jan 30, 2014 5:17 pm
Corps....by the looks of that hydro I would say that wash as finished. It's reading 1.000 as far as I can see, stick it somewhere cold to clear.
Also you say your "temp strip" reads 22/24, a lot of folks I know that brew their own will not use these strips as they "may not" be correct.
As the other guys say, the lower the temp the longer the ferment.
BJ...Image
Re: Lentil Wash
Postby Almanac » Thu Jan 30, 2014 7:31 pm
In a 60lt wash I would have used 800g of lentils with 10kg of sugar and given that you used 11kg I'd have upped the lentils to 1kg. I'd say the wash has stalled from lack of nutrients and low pH.
Soak about 300g of lentils in boiling water and allow to cool to about 25oC then add 2tsp of Sodium Bicarb and add the lot to the wash. Give it all a good stir and close the lid. It should re-start OK. The FG should be 0.990 or lower.
If you don't have a means of maintaining higher temps maybe you should use smaller fermenters, especially if you're using an Airstill ;)
Re: Lentil Wash
Postby chill » Thu Jan 30, 2014 11:13 pm
2tsp or 2 Tbsp? 2tsp of baking soda in that much liquid does not sound like enough to me.
Re: Lentil Wash
Postby Easydrinker » Thu Jan 30, 2014 11:19 pm
Phantom wrote:Excellent.......
The alco tech 48, should (from memory), be quickest, but like with anything Rob, it often comes down to the numbers - hence I happily use vodka star and because I get away with no carbon and not fining it, it costs me the sugar, the yeast/nutrient pack and the cost of leccy/water to cool my T500, so half the price of using a full SS triple distilled wash pack(s)......
You were right with the timings Phantom,racked the alcotec tonight at .984,will do the vodka star tomorrow at the same FG,(by then),and hopefully the lentil wash the next day,still just fizzing,nearly done.
All had the same heat and sugar,and the turbos had just half a packet.
The cost comparisons are really negligible,in order(excluding sugar),£1.05,.88p and .77p for the lentils and half a tub of Allinsons,mainly due to discovering https://www.discountbrew.co.uk/, who I recommend to all,good prices and service.
I have a packet of the SS triple distilled stuff,came with the Smart Still,which I don't fancy using any time soon.
I will happily be using turbo clear in all washes,half a pack,47p,worth it for the speed of clearing.
From tomorrow,due to a couple of strips sitting waiting,I will be running the still for the next seven nights,no,it will be longer.
Ain't life a bitch?
Then I will be able to relax a little and finally get my peated malt going before it goes fousty.
Re: Lentil Wash
Postby Almanac » Fri Jan 31, 2014 12:06 am
chill wrote:2tsp or 2 Tbsp? 2tsp of baking soda in that much liquid does not sound like enough to me.
I hear you Chuck, but without a pH measurement I thought it best to suggest a small change. Two teaspoons won't change the world but if the pH has dropped too low it should be enough to make a difference and get the wash restarted without raising it too much in one go. ;)
Re: Lentil Wash
Postby Corps012588 » Mon Feb 03, 2014 8:15 am
Hi Aidan.
Been on holiday so only just read your reply.
Checked the was again today and here's the result.
It has actually dried up a bit more!
Shall I just leave it?
Corps012588
Re: Lentil Wash
Postby Almanac » Mon Feb 03, 2014 8:23 am
I'd suggest tasting the wash and if it's still sweet on the tongue you'll need to get the wash to finish before trying to strip it. A pH test would be of great help to determine if the wash has stalled ;)
However, if it tastes dry get it stripped quickly, so it doesn't have any chance of picking up an infection, then you can take your time doing the spirit runs. ;D
Return to Recipes
