New still cleaning
Post Reply
Jennysgin
Valued Member
New still cleaning
Post by Jennysgin » Tue May 14, 2019 4:38 pm
The air still is meant to be arriving tomorrow! :D
Should it be getting a water and vinegar cleaning run before use like the bigger stills or should it be ok to go?
Thanks
Admin/Donated to SS
Re: New still cleaning
Post by Easydrinker » Tue May 14, 2019 11:37 pm
You will be good just running some water through it to clean out any residual manufacturing oils etc.
Vinegar is really only used for soldered home builds.
Jennysgin
Valued Member
Post by Jennysgin » Wed May 15, 2019 4:01 pm
Thanks Easydrinker :D
Valued Member / Donated to SS
Post by Mash » Fri May 17, 2019 6:42 am
Jenny - you have had it a week now have at least how many gallons of you made. :D
To Gin-finity and beyond !
Jennysgin
Valued Member
Post by Jennysgin » Fri May 17, 2019 3:14 pm
None yet! :cry: It only arrived on Wednesday. I ended up getting a basic starter set as we had absolutely no equipment so now we have a fermenting barrel the first wash is on. We're using up the turbo pure that came with the still but will try other things for the next one :D
Post by Mash » Fri May 17, 2019 3:18 pm
Good luck. I'm sure it will make you grin. You should find the forum is a lot more use than the instructions.
Get some copper saved up for when you run it.
Jennysgin
Valued Member
Post by Jennysgin » Fri May 17, 2019 3:37 pm
Already on it! ;) The forum has been really helpful already.
Post Reply
