Cleaning an air still?
Post Reply
borntobewild
Valued Member
Post by borntobewild » Thu Jun 13, 2019 3:03 pm
I only clean my still with boiling hot water and nothing else, after every batch I take the lid off and pour hot water in the little hole 3 times.
Is that enough or should I use something else every so often? Guess I'm worried the hole might get clogged up at some point.
piglets
Valued Member
Re: Cleaning an air still?
Post by piglets » Thu Jun 13, 2019 9:32 pm
Good question, I find it very interesting what others tend to do.
I guess there is no better desinfectuin than running the still with clear water; hence; steam desinfection.
Curmudgeon
Valued Member / Donated to SS
Post by Curmudgeon » Fri Jun 14, 2019 12:03 am
I confess to never having cleaned mine other than removing any crud from the inside of the kettle with a little bit of heads as soon as it is cool enough.
Slowly slowly, catchy funky
Don't stress the yeast
Post by gaza the instructor » Fri Jun 14, 2019 7:39 am
I clean mine with brewers bleach. Reason is Gin is
a dirty business.
Mirror-signal-manoeuvre.
captainfog
Valued Member
Post by captainfog » Fri Jun 14, 2019 10:08 am
I do a water run before I any gin run. It serves two purposes. Firstly it cleans the still and secondly I use the distilled water to dilute my gin down to my preferred ABV.
When I do a water run I always discard the first 250ml because it smells a bit funky - a slight stripping run whiff. The water that comes out after that is perfect though.
Post by Mash » Fri Jun 14, 2019 6:16 pm
I tend to run spirits inbetween gins. But apart from that I am only cleaning the kettle with TFR & a scrubby
To Gin-finity and beyond !
borntobewild
Valued Member
Post by borntobewild » Fri Jun 14, 2019 6:48 pm
Ok then, I feel better now I know everyone is pretty similar.
Wasn't sure if people maybe put a bit of vwp or something similar inside the lid every now and then.
I'll continue as I am then, maybe use a bit of the heads to clean as curmudgeon suggests
Post by Mash » Fri Jun 14, 2019 8:05 pm
It's a boiler. Just keep the crud down.
Post by gaza the instructor » Fri Jun 14, 2019 10:16 pm
What is TFR Mash or am I just a TOTAL FIN' RETARD,
be polite I have been testing Gin again!!!
Post Reply
