Leaving ethanol in the filter
samleeds
Valued Member / Donated to SS
Post by samleeds »
In the past I always flushed the water out of the filter and chucked it when the ethanol appeared, then after filtering I would chase the ethanol out by using fresh ro water which stayed in the filter so as not to dry it out. My new filter is pretty big, so could I leave the ethanol in it, so I don't need to prat around with flushing. Ive got plenty of ethanol to work with so leaving a litre or so in the filter wouldn't hurt me, but when it comes round time to filter another batch in a month or so, can I still use the ethanol that has been sitting in the carbon in the filter. If that's ok I can just fill the reservoir and filter and mix, filter and mix and so on.
popalop
Valued Member
Re: Leaving ethanol in the filter
Post by popalop »
I always flush with water and throw carbon then use fresh next time
samleeds
Post by samleeds »
popalop wrote: Fri Feb 05, 2021 2:36 pm I always flush with water and throw carbon then use fresh next time
The amount of carbon in my filter will do 60 litres. I meant if I only put through 20 litres, can the ethanol stay there till i get another batch to run which is usually 2 weeks
Post by gaza the instructor »
I don't see why not. If the carbon was going to taint the alcohol
in any way, you wouldn't put it in there in the first place.
As long as bugs can't get in the only problem you may have is
"The Angels Share" ie; they could be partying on your roof!!
Mirror-signal-manoeuvre.
samleeds
Post by samleeds »
gaza the instructor wrote: Fri Feb 05, 2021 4:31 pm I don't see why not. If the carbon was going to taint the alcohol
On that score, I am agnostic and the angels dont get anything as my filter is airtight and sealed both ends. lol.
They can cure that Mate, two house bricks and whammmo
mind your thumbs. You will loose some so the Angels will
get a drink, if not they sit on the end of your bed and bite
your toes.
Admin/Donated to SS
Post by Easydrinker »
I simply run my Essencia half a dozen times or so, and then switch the carbon.
It is a personal choice.
There is no one way.
Admin/Donated to SS
Post by Mash »
Ed. Absolutely... Why are you flushing with water? This is introducing a problem.
To Gin-finity and beyond !
Admin/Donated to SS
If you have enough neutral to leave your essencia charged, then you will lose a little to the angels.
Admin/Donated to SS
Post by Mash »
Water goes grotty on its own, 40% does not.
This is why I have junkahol.
Admin/Donated to SS
I have more 40% + tails than I can currently shake a stick at.
Thinking of setting them free .
Though I hate the teen's popularity, if Greta has any good ideas...?
Elecrafter
Post by Elecrafter »
Interesting... I just got a SS filter, the big stainless one. Takes 500gm of carbon, and so far has made a big difference to the couple of runs I have put through it. I was wondering how much I could filter thru it before changing the carbon, and I also thought of keeping some ethanol in it to stop it drying out. If I flushed it it's just introducing more water into the ethanol, and also me needing to produce more RO water to flush with. So far getting some good clean tasting and clean smelling neutral out of it. Reasonably pleased apart from the price.
Ele
phantom
Moderator/Donated to SS
Post by phantom »
Elecrafter wrote: Mon Jul 26, 2021 10:47 pm Interesting... I just got a SS filter, the big stainless one. Takes 500gm of carbon, and so far has made a big difference to the couple of runs I have put through it. I was wondering how much I could filter thru it before changing the carbon, and I also thought of keeping some ethanol in it to stop it drying out. If I flushed it it's just introducing more water into the ethanol, and also me needing to produce more RO water to flush with. So far getting some good clean tasting and clean smelling neutral out of it. Reasonably pleased apart from the price.
Ele
I use a freshly charged Z filter and put a max of 50 litres through it (at about the 40% area).
It uses about 300ml of carbon, so then it gets removed and the filter recharged.
The "spent" carbon is the rinsed repeatedly in boiling water (as per Gert Strand's - Carbon filter ebook. When there's no smell of spirit left, it's dried out on a baking tray in a low oven, then once dry it goes back into my carbon stash.
Seems to work well
Valued Member
Post by Icefever »
I'm just catching up on this thread, interesting for me because in my AS days I did use the filter. Then you read more & more about using carbon, some folks say "if you do the job correct, you don't need to filter". I've read Gert's book and to a layman like me it makes sense, I do have a bag of carbon in the cupboard, and I did a run with a small homemade filter just the other month.
I watched George on youtube make a tube filter, and he seems to make a lot of sense about filtering likker. I have a 4" SS section in the garage, heaven only knows how I came by it, I can't remember buying it. The other week while doing a spirit run I came across it, then a bulb went off in the old grey matter....I use a 2"x 4"x 2" torpedo, use one side of the torpedo down to 2", reduce to 15mm, add a tap to control flow and ally hoop one filter tube.
Just in case you may have missed the vid....link...https://www.youtube.com/watch?v=yeJCOROQlXo
Ice.
It's better to try and fail than fail to try
Valued Member
Post by Icefever »
I managed to finish this tube filter, I'll need to fit some sort of bracket and maybe fix it to the wall?? The photo is in 2 shots, job to get it all in without being too far away then there's no detail. The SS section is 12" x 4" tall, then there's about another 12".
Ice.
Moss
Admin & IT Bod
Contact:
Post by Moss »
@Icefever
It is perfectly acceptable to post your images directly into your post, no need to use a service like Postimage.
My heart nearly stopped when I tapped your image and it opened with adverts!
Moss
Have you tried turning it off and back on again?
“Are you not entertained?” Maximus Decimus Meridius
If it’s broken, it might be my fault, is my responsibility and there is even a slight chance I can fix it 😳
Admin/Donated to SS
I don't think Ice is promoting ads.
Maybe just a touch of Old Skool, save bandwidth sort of thing.
Or uploading for multiple site usage?
Let's leave ads behind, this is one place that I can come and not see them, without using an ad-blocker!
Valued Member
Post by Icefever »
Moss wrote: Tue Jul 27, 2021 7:54 pm @Icefever
Moss
Sorry, Moss didn't intend to give you a coronary, it was the way on the old site to save space. I'll upload in the future mate.
Now uploaded to forum.. ;)
Ice.
Moss
Admin & IT Bod
Contact:
Post by Moss »
Easydrinker wrote: Wed Jul 28, 2021 12:11 am I don't think Ice is promoting ads.
Please don’t misunderstand me - the initial shock was soon over.
I just wanted to point out that we are a bit looser about this kind of thing. It is easier to use our server and as long as our members are as generous as they are now, we can continue to make it easier.
Moss
Admin & IT Bod
Contact:
Post by Moss »
Icefever wrote: Wed Jul 28, 2021 4:39 am
Moss
Ice.
Any way that is good for you Ice - you can upload however you wish, we really don’t mind.
Moss
Admin & IT Bod
Contact:
Post by Moss »
Just looked at the images again and they display better when they are included in the post anyway 😎
Admin/Donated to SS
Leaving the last few posts on one side;
That is one of the prettiest filters I have seen.
Nice one Ice.
Elecrafter
Just as an aside, but related topic....
How much spirit (max) would you filter through 500gm of Activated Carbon?
Sort of average / ball park figure would be fine.
Reason is, just sorted a tall filter of about 1.5" dia, and it takes about 500gm of carbon, and don't want to waste it unnecessarily.
Ele.
Valued Member
Post by Icefever »
Elecrafter wrote: Sat Jul 31, 2021 12:07 pm Just as an aside, but related topic....
Ele.
If I remember correctly in the above video any tube under 2"dia will not work properly??? the liquid runs down the inside wall of the filter and doesn't work as well. He also tells you how much likker can be treated with a certain amount of carbon.
Ice.
phantom
Post by phantom »
Ele.
Well I think my "Z" filter holds about 300gm per charge. I try to aim for 10 ltr batches as that's the reservoir bucket holds. I find I get good results for about 40 litres (and that's running the spirit through twice). I make sure that the spirit is IRO 40% ABV, but I don't worry about being exact, just as long as it's 40% minimum (highest I've run through the filter unit is about 45%).
Equally, once I consider the carbon "spent" I use Gert Strands method to clean it up for reuse (once I get no smell of spirit from it, I dry it out in a low oven temp, then it just goes back into the bag of dry stuff for reuse - means I only get a new bag once a year).......
But as with anything like this YMMV..........
Post Reply
