Red-Neck Essencia filter tap fix
Post Reply
Admin/Donated to SS
Post by Easydrinker »
The black plastic top component of my tap recently failed.
Lazy bugger that I am, 5 minutes with a drill. some stripped copper cable, a pair of pliers and a small piece of hammered flat 15mm copper pipe, I have a work-around.
It has lasted several weeks so far...
RedNeck repair.jpg (158.71 KiB) Viewed 1557 times
I will probably add resin (Araldite) and hope that it lasts.
Admin/Donated to SS
Re: Red-Neck Essencia filter tap fix
Post by Mash »
I have replaced these taps in the past. EBay might be a good place "tea urn" or "burco taps" will get you there. Normally less than £10
To Gin-finity and beyond !
Valued Member / Donated to SS
Post by gaza the instructor »
Never looked but is the tap secured by a retaining nut on the inside.
If so Mash is right (as usual ) you could fit a new tap.
TBH do not use a filter very often.
Mirror-signal-manoeuvre.
Post Reply
