Nuking Spirits In The Microwave
Postby Chubbs » Mon May 08, 2017 7:39 pm
Thought I would start a new new topic after just reading 'gaza the instructor' mention the method of making his own JD with chips and a microwave on another post.
I've read quite a few topics about this over the last few months, and I'm intrigued.
I have a box of Jim Beam chips in the shed which I bought last year sometime and thinking about giving it a go. So how do you guys do it. Do you char the chips at all before soaking. Is it safe.
Cheers.
Chubbs
Stills: Air Still & T500
Re: Nuking Spirits In The Microwave
Postby Curmudgeon » Mon May 08, 2017 9:05 pm
viewtopic.php?f=6&t=2034
http://homedistiller.org/forum/viewtopi ... =4&t=38991
It is definitely safe, given usual sensible precautions such as not smoking, having a gas burner lit or other naked flames nearby etc
Curmudgeon
Stills: pot head
Postby Easydrinker » Mon May 08, 2017 10:29 pm
Curmudgeon says it straight.
I do this sometimes, without hesitation.
Use common sense and intelligence.
Postby Mash » Tue May 09, 2017 5:58 am
There is also some stuff on here...
viewtopic.php?f=6&t=2034&start=60
Postby gaza the instructor » Tue May 09, 2017 7:16 am
It does work very well.
Postby Mash » Tue May 09, 2017 3:50 pm
JD is stunningly close.
Postby Easydrinker » Tue May 09, 2017 11:49 pm
I had totally forgotten this thread.
I would like to add that starting with a whiskey aimed/flavoured brew will help achieve a better finished whiskey than just using a neutral.
Try it.
Postby gaza the instructor » Wed May 10, 2017 6:43 am
I now neuk and vigorously shake once a day for
three days. Then strain and bottle on the 4th.
Any more and it seams to go a bit woody.
With the JD try adding a little Maple Syrup on
last neuking Yum Yum :)
Return to Recipes
