t500 hosepipe mod
t500 hosepipe mod
hi all..
i did this mod to my t500 water control thingy and it works a treat!..
all i did was solder a piece of standard 15mm copper pipe to the supplied adaptor(that fits hardly anything) and viola!...
all i do now is to push the hosepipe onto the end and turn the water on but not too fast or it will blow off!.... i have found that i can control the water perfectly by turning the
t500 water adjuster on to its fullest setting and then turning the hose tap down to a decent trickle but too fast for the t500's recomended 400 ish ml per min, and then adjusting the adjuster until i reach the desired water flow and temp on the t500..
hth
al.
hth
al.
oooooooh my head.....
i dont drink - ***BANNED***
- Stills: t500
shoutingsoup - Newcomer
Re: t500 hosepipe mod
easy way to connect the needle valve to 15mm copper 3/8 male iron to 15mm copper,
alan - Donated to StillSmart
- Stills: airstillT500 2in ph
