t500 rashig rings
• Page 2 of 2 • 1, 2
Re: t500 rashig rings
right.. were getting there.
so a copper at the top (under the coil), then ss, then copper at the bottom quite densly packed.
then run at 55-60'c.
sound about right?
sound about right?
beerbeermorebeer - Regular
beerbeermorebeer wrote:right.. were getting there.
then run at 55-60'c. sound about right?
Yep, Copper - SS - Copper
You can actually push it higher than that as the HETP value of scrubbers is a lot better than raschigs or saddles giving more reflux for the same height, but lower is always better.
If you don't know this site, it needs reading:http://homedistiller.org/intro
vino-tinto - Senior Distiller
HETP value?
laymans terms please.. im a home brewer not a rocket scientist lol
and iv spent the last fortnight on that site and got nothing but contradictions.
thats why i asked in here.
hetp somethng something theoretical plates
bigger value more reflux per height measure so you can have a shorter column and higher ouput %
imho run as per usual and only if the collection rate is significantly slower consider running at a higher temp, running faster/hotter could be counterproductive.
bigger value more reflux per height measure so you can have a shorter column and higher ouput % imho run as per usual and only if the collection rate is significantly slower consider running at a higher temp, running faster/hotter could be counterproductive.
Fil - Experienced Distiller
beerbeermorebeer wrote:HETP value?
Don't go into the forum on the link I posted, but read the site contents, especially "Theory"
