sugar wash with added wine...will it work.
Postby guest5234 » Tue Nov 01, 2016 11:11 pm
I have 2 x 5 gallon of sugar washes that I want to make into gin with a strip run through my alembic pot still then a spirt run through my t500 column and finally another spirit run with botanicals through the pot still again....I have 2 gallon on homemade wine from a kit, can I add this to the wash?
guest5234
Re: sugar wash with added wine...will it work.
Postby Curmudgeon » Wed Nov 02, 2016 12:01 am
You don't need a full boiler any more than you need a full kettle to make tea.
The column with a good reflux (slow output) should give you a neutral spirit for sure, but personally I'd keep stuff separate and do smaller runs if I was making for anyone other than myself. I couldn't taste the difference, but maybe you can.
Curmudgeon
Stills: pot head
Postby guest5234 » Wed Nov 02, 2016 12:11 am
Curmudgeon wrote:You don't need a full boiler any more than you need a full kettle to make tea.
Thanks mate, I only meant would the wine make any flavor difference to the final product if I added it to the wash.
guest5234
Postby Easydrinker » Wed Nov 02, 2016 3:12 am
After distillation,I would say no discernable flavour difference from the added wine...
HTH
Postby Mash » Wed Nov 02, 2016 5:45 am
Gin base is neutral. Reflux will make neutral.
No point NOT chucking it all in. I would.
Postby gaza the instructor » Wed Nov 02, 2016 6:00 am
T500 column is good for striping
flavour out if you run nice and
slow you will get good neutral. :)
Postby guest5234 » Wed Nov 02, 2016 5:22 pm
cheers guys, in it goes next run.
guest5234
Postby Curmudgeon » Thu Nov 03, 2016 1:11 am
Heathens! ;D ;D ;D
Curmudgeon
Stills: pot head
Postby Mash » Thu Nov 03, 2016 6:58 am
Welcome brother :D
Postby inspector gadget » Thu Nov 03, 2016 8:23 am
I have many bottles of ghastly wine and if this kale wash ever finishes then I may just dump them in the last still run to top it up.
inspector gadget
Stills: SmartStill,T500
Postby Dave » Thu Nov 03, 2016 3:08 pm
My very first (I've only done two) run was two gallons of uninteresting wine I'd made earlier this year! I'd made some red wine from Lidl grape juice that finished very acidic, so split it into two demi johns, one with 2 liters of apple juice, and the other with 2 liters of prune juice, and fermented them out. They were both not very nice, so just left them alone.
Meanwhile, I made my still, and true to form, didn't heed advice and put a mash on in time, so was looking round for something to distill, and thought of those two DJ's of wine, and ran them. It turned out absolutely gorgeous! If that is all I can ever make, I'll be happy! I pine for several gallons of that nectar! 8)
Dave
Postby Easydrinker » Thu Nov 03, 2016 10:03 pm
Sometimes that is the way, you expect little and are well rewarded.
Sometimes you expect a lot due to expense or effort and are bitterly disappointed.
Sometimes it is chance. :)
Users browsing this forum: No registered users and 4 guests
In total there are 4 users online :: 0 registered, 0 hidden and 4 guests (based on users active over the past 5 minutes)
