Double or Triple Distill
Postby Distillingchris » Sun Dec 07, 2014 5:06 pm
More questions, have just ran first load through and want to know if any has or there a difference between double distilling or doing another stripping run and doing triple distillation. Wash is just sugar and water.
Distillingchris
Stills: Airstill
Re: Double or Triple Distill
Postby Admiral Toad » Sun Dec 07, 2014 7:22 pm
2 runs is best but better guys and threads on here to guide you
Admiral Toad
Stills: pothead, BP column
Postby Myles » Thu Dec 11, 2014 4:06 pm
Strip run then spirit run is double, redilute and do another spirit is triple.
each time you re dilute for another spirit run lightens the flavour.
This is for a pot still. Typicaly your first strip run from fermented wash will take you to about 30% - possibly a bit less.
You modify these low wines to about 27% and do a spirit run. If you wish to do a third run you take the hearts, dilute to 27% again and do another spirit run.
Do a 4th and you are probably close to pot distilled vodka.
Irish whisky is often 3x distilled, it just depends what ferment you had to start with, and what taste you like.
Return to Distillation
