Our latest purchase
Re: Our latest purchase
Postby Phantom » Tue Aug 05, 2014 3:21 am
TVM Robert.......
I can see a few potential extra bits that'd need sorting, but it does seem to offer all the flexibility to be able to connect up most different arrangements i.e. a pot head, any number of different reflux columns etc.....
Nice.......
Postby Opus 27 » Wed Aug 06, 2014 1:16 pm
Some answers coming up,
Cost £180.00
Heating, Electric element on the way ( 2KW)
Element fits in tri-clamp plate threaded 1"BSP
Also found 40 amp SSR power controler for under £10.00. Tried it on 1400 watt heater and could vary power from full down to 160 watts.
Opus
Opus 27
Postby Opus 27 » Sun Aug 31, 2014 12:52 pm
Fitted a 2KW heater (actually producing 2.4 KW) works fine but ordered a 3KW to try. Higher power purely for initial heat up. Once up to temperature with both pot and reflux column we seem to settle between 1100 and 1600 watts prgressing to the higher temp as we approach tails.
Opus
Opus 27
Postby Phantom » Sun Aug 31, 2014 2:23 pm
Opus 27 wrote:Fitted a 2KW heater (actually producing 2.4 KW) works fine but ordered a 3KW to try. Higher power purely for initial heat up. Once up to temperature with both pot and reflux column we seem to settle between 1100 and 1600 watts prgressing to the higher temp as we approach tails.
Opus
Nice.........
Postby RumJohn » Mon Sep 01, 2014 3:58 am
ATTN: AM:
Knew you couldnt stay away.
RumJohn
Stills: Homegrown
Postby RumJohn » Wed Sep 24, 2014 1:19 am
Some nice gear Opus. For others that might be interested, I buy all my stainless steel tanks, etc. through www.alibaba.com. Then look around in alcohol distillation, or milk tanks, or fermentation tanks, etc.
RumJohn
Stills: Homegrown
Postby Almanac » Wed Sep 24, 2014 8:10 am
Being in that part of the world does help though, Yes?
Postby RumJohn » Thu Sep 25, 2014 3:41 am
@AM: Yes - there are advantages to being in this part of the world, but Alibaba is set up for people from all over the world to be able to find items anywhere that they are produced. Not just China.
Take a look at their site. I like to check on what is available from time to time.
RumJohn
Stills: Homegrown
Postby Almanac » Thu Sep 25, 2014 10:38 am
Alibaba and Sourcing Map are my two main 'Go To' sites when searching for things I can't find or afford in my little country ::)
