Spent Saturday afternoon contemplating the intended 'new' layout and arrangement of my rig in my new workshop and after two hours of farting about I had achieved/decided absolutely nothing, I just couldn't get the brain in gear
Thankfully I was able to get the plans down on paper this morning. It's not that it is complicated or anything it's just me being me
Have just racked off a batch of elderflower cider (for Mrs H). I made up some Drambuie yesterday, and I'm planning to enjoy that whilst watching the F1.
heggsy - Regular
BTW I did a test last Sept with my juicer and 10lbs of Rooster spuds. I got loads of juice and a pile of potato pulp.
While I heated the juice to 50oC I put the pulp into another pot with 5lt of warm water and as a sparge. I strained this mix into the potato starch and added 1 tsp of powdered Alpha Amylase and 1/4tsp Gluco Amylase which converted all the starch to sugars.
I used the Tincture of Iodine test to make sure there were no starches left.
that's as far as I took it and added the liquid to a standard wash I was mixing at the time and I had intended to do a full wash from spuds this year but haven't gotten around to it.
I worked my ring off doing farm maintenance in 35 deg C (shade temp)then, like an epiphany, I called in my ancestral 'rights'....it is St Patricks Day afterall
so the stout and whisky have taken me to here and beyond (ie bedtime....
Croí follain agus gob fliuch.
) Croí follain agus gob fliuch.
Frank - Senior Distiller
- Stills: Potstill,LM Boka
one more stripping run from the Air Still and one more spirit run later tonight, then let it air for a a bit
Lasagna and ribs for dinner followed by some cards with family
All roads lead to rum!!
KerryW - Experienced Distiller
- Stills: Air Still & T500
out and about and ended up at the range and found a couple of bargains
see here >>> viewtopic.php?f=5&t=1847
also was thinkin about gettin a batch of wine on the go as im down to me last
gallon,but probably do that termoz now
Magnu420 - Senior Distiller
With the help from chill, and mooge I blended my first sambucca using anise essential oil and blended my first gin using chill's recipe minus a couple herbs that I couldn't find but I got the most important ones. Can't wait to taste the results. Thanks fella's for the help
edwatters - Donated to StillSmart
Tarmini time!
Attn: Edwatters
I make 3 different heat levels of chili vodka. The first two levels I just add 1 and/2 chilis to the vodka and let sit for a couple of months. The hot pot is a combination of Szechuan peppers that are normally used in a hot pot cook up. Would send some pics if I knew how.
Made the cuts on a turbo wash,, blended and trying a sample,,
I have to get some JD chips somewhere,, somehow I ended up with 3 spirit runs and turned out 5.4 l # 40% so at approx 23 $ spent on sugar, turbo yeast, filter I am saving approx 200 dollars >:D
Thanks rumjohn but it burns enough for me without the peppers lol
waited in for a delivary of a boiler,then eagerly ripped the box open
only to find that the boiler is a 20L,not 30L as the seller stated
gonna try get summat sorted with seller,if no joy il make a complaint
to paypal and ebay
to paypal and ebay
Ran 2 x 20l Fine Scotch Whisky stripruns (no puke, collected down to 8l per) through the potstill...all good
Mashed/sparged and kicked off fermentation on 2x 20l new FSW washes...all promising
Bottled 25l of K&K homebrew beer....tell you in a couple of months
...Anyway, time for a drink
I put a yeast starter on last night for pitching this evening. Came down the stairs this morning and the buggers (yeasties) must have had some party during the night and have overflowed the 3lt jar I normally grow my starters in. Lovely malty aroma around the house
don't know if SWMBO will enjoy the aroma as much as me though!
Well over last couple of days picked up latest peated malt and got 25 kg of LME at a very reasonable £60 in a proper none burst plastic jerry can
Oh a mashing I will go this weekend....... things are gonna get sticky
- Stills: pothead, BP column
