Small Parrot
Small Parrot
Hi can anyone recommend where I can buy a small parrot to use with air still. I had the small glass one from stilldragon but unfortunately it seems to have cracked at the bottom:(
alien1984 - Regular
Re: Small Parrot
Hi there I have just ordered the same one from SD, have you thought about finding a local glass blower that can fix the crack? I am going to have a go at building Benoit's 'bouncing parrot later , the thread is here here I am planning to make a stainless spring to go in my glass one to stop the hydrometer hitting the bottom. Hope you find a solution.
- Stills: SmartStill,T500
Re: Small Parrot
I wondered if there was a type of rubber or silicone that doesn't float. That way a small disc could be dropped in to act as a cushion.
Re: Small Parrot
Alien, you asked where you might purchase a small parrot.
Unlike a number of our members, who can turn their hands to produce some quite wonderful and often beautiful things, I have no such skills at all.
In the past I have found this supplier very helpful in making up bespoke copper items to my own requirements.
http://www.distillingdominoes.co.uk/dis ... er-parrot/
If you contact him and supply details of what you want, he would quote you a price. I'm sure he could build a small copper parrot to meet your requirements.
T
Toper - Senior Distiller
- Stills: Copper Pot Still
Re: Small Parrot
Thats very pretty and hes a good bloke. Read the blog - ring him - fantastic.
Re: Small Parrot
On all parrots you should put in a bit of copper or stainless mesh in the bottom to act as a cushion just in case you drop the hydrometer in. Or as mentioned a spring of some sort.
Re: Small Parrot
I can't stop myself...
It has seased to be, it is no more, it has run up the curtains, to join the choir invisible.
It is a dead parrot!
Re: Small Parrot
Lmao.
Why did I not see that coming.
Re: Small Parrot
Myles wrote:... a bit of copper or stainless mesh in the bottom to act as a cushion ...
Doh!
Thanks Miles
