T500 Parrot
T500 Parrot
Latest news.
Imake the makers of T500 & Grainfather have issued a recall on the copper parrot they sell, retailers are told to make full refund. No reason given for recall.
vino-tinto - Senior Distiller
Re: T500 Parrot
That doesn't sound good...
Brewhunter - Senior Distiller
- Stills: T500 + Airstill
Re: T500 Parrot
For what it is, I can only see it containing high levels of lead in any solder they have used.
What else could it be.
Chubbs - Regular
- Stills: Air Still & T500
Re: T500 Parrot
Given Imakes level of exposure to the home brew industry as a whole I wouldn't expect that to be the case....
Having said that am aware of some odd occurrences from that direction, time to time.
And then, manufacturing in (cough, cough) China, sometimes you get what you pay for/don't pay for - delete as applicable......
Re: T500 Parrot
I would guess Lead as the reason here, but what do I know?
Re: T500 Parrot
+1 there really isn't anything else
Re: T500 Parrot
Have just noticed the parrot recall only affects parrots used with the alembic dome.
If parrot were purchased to use with T500, recall doesn't apply.
Would indicate issue is not leaden.....
Re: T500 Parrot
I confess I only saw the one parrot for both types (UK)
Curmudgeon - Master Distiller
- Stills: pot head
Re: T500 Parrot
its a lot of money and yes i did say that.
Ps. Temp that distillate comes out of the copper condenser is
quite high, maybe peps have been scalding them selves
- Stills: s.s&t500 copper
Re: T500 Parrot
Curmudgeon wrote:I confess I only saw the one parrot for both types (UK)
Your eyes did NOT let you down....
Re: T500 Parrot
gaza the instructor wrote:its a lot of money and yes i did say that.
Well there's the thing I can't savvy......why peeps are so proudly quoting, and showing, their off-take results at the parrot
Those results are skewed, surely
I'd love to have a parrot but my off-take temps are so high I just set the lot aside until the next day when I can extract some meaningful %'s........
Re: T500 Parrot
I guess that your parrot needs space for a thermometer as well, then you can do the math.
Or fit some control to reduce the temp. of the distillate.
Or wait until the next day....
Re: T500 Parrot
Longer run of curly copper before the parrot would help.
Re: T500 Parrot
[/quote]
I dont use parrot on a spirit run only a strip run.
I use a Refractometer and collect in jars like most
of us do
[/quote]I dont use parrot on a spirit run only a strip run.
of us do
Re: T500 Parrot
The Temp is pretty good out of the AS, but even so there is massive inaccuracy do to the volumes - and the fact we will be mixing it all together .....
I use mine as a progress indicator on the webcam.
