bought a t-500 and would love some tips and tricks for it.
Info specific to the T500
Postby danmiz » Thu Aug 02, 2012 5:07 am
Hi all!
i just bought a t 500 and and am i ever very excited. ive read everything over and over and am wonder are there any tips out there that i didnt read about that i should know about the t 500? thans in advance!
danmiz
Re: bought a t-500 and would love some tips and tricks for i
Postby MrCat » Thu Aug 02, 2012 8:46 am
Just a couple I know about.
Just make sure you connect the water pipes up the right way around :)
Get some PTFE tape in case of leaks.
I have a power controller so I get the T500 up to the boil, increase the water and reduce the power to compress the heads as much as possible, then put the power back up to max to collect the hearts.
If you are charging the boiler with stripped wash (or low wines) then dilute the wash down to 30% as this allows for better separation of the heads (thanks CC for that one)
MrCat
Postby danmiz » Thu Aug 02, 2012 10:22 am
Thanks mrcat!
danmiz
Postby Andy » Thu Aug 02, 2012 10:30 am
I gave you my tips "over there" LOL
Andy
Postby danmiz » Thu Aug 02, 2012 4:55 pm
Haha. I try to get as advice as possible.
danmiz
Postby Admiral Toad » Thu Aug 02, 2012 8:03 pm
Hi mate
From my experience
Water pressure is everything look at mine and earlier posts about introducing a pressure releif valve makes life so much easier
And once column is packed and right way up tap the top to drop copper and ceramic packing off the coil. Works soo much better
Enjoy ;D
Admiral Toad
Stills: pothead, BP column
Postby danmiz » Fri Aug 03, 2012 5:00 am
THanks AT!
danmiz
Postby Andy » Fri Aug 03, 2012 6:01 am
In all honesty Dan, the best advice I could offer is HAVE FUN and ENJOY the hobby O0
Try different recipes, try not to take it all too seriously and you will fall into your own rhythm with what suits you and your taste.
Andy
Postby danmiz » Fri Aug 03, 2012 12:21 pm
Will do Andy!
danmiz
Return to T500
