So many different opinions.
Postby guest5234 » Tue Oct 25, 2016 10:04 am
Thought I had this Gin run sussed but when I posted on another site the opinion was different....this is how I was told was the best way on this forum which I greatly appreciate.
1. Strip run with alembic pot still
2.1st spirit run with T500 column making cuts
3 2nd spirit run just using hearts from 1st spirit run in alembic pot still with botanicals with no cuts.
Some people think I should only make cuts on the last spirit run No 3 and no cuts on No2
guest5234
Re: So many different opinions.
Postby Mash » Tue Oct 25, 2016 12:03 pm
Old Chinese proverb:
Man with two watches never know what time is !
There is always more hat one way - try one - try another see whats fits you best !
Postby Anavrin » Tue Oct 25, 2016 2:04 pm
All methods will give you a drinkable Gin, however if you flavour with botanicals before making cuts, you are waisting botanicals, in the heads/tails you don't use, it will also be harder to make your cuts once everything's been flavoured.
Postby guest5234 » Tue Oct 25, 2016 2:16 pm
Cheers, will use the original one posted on here
guest5234
Postby Icefever » Tue Oct 25, 2016 3:14 pm
I made this point a while back, one has to be careful, you have to have faith in the guys you're asking....there are far too many "Experts" on the web on every subject.
I always say "Ask ten guys a question...and you'll get eleven answers. ;D
Also +1 with Anavrin.
Postby gaza the instructor » Tue Oct 25, 2016 4:02 pm
There are some good Gin guys on this
forum Guest5234.
Remember... They Drink What They Make!!!!
Postby AFK@420 » Tue Oct 25, 2016 4:33 pm
You mean to say there are other forums on the interweb??? ::)
AFK@420
Postby guest5234 » Tue Oct 25, 2016 5:14 pm
yep, and all have different ways of doing things :) I have learned quickly that there are many ways to skin a cat ;)
guest5234
Postby guest5234 » Tue Oct 25, 2016 5:15 pm
gaza the instructor wrote:There are some good Gin guys on this
forum Guest5234.
I know and that is why I am sticking only with this forum....
guest5234
Postby Myles » Tue Oct 25, 2016 5:54 pm
Most of the time, even when making genever, you have a clean base spirit before flavouring.
Often there is a small cut on the final run but this is actually for oils, it isn't a heads cut in the conventional sense.
Postby Easydrinker » Tue Oct 25, 2016 11:00 pm
guest5234 wrote:yep, and all have different ways of doing things :) I have learned quickly that there are many ways to skin a cat ;)
I love you and want to have your babies. :) :)
You seem to understand all the shit that I have been pushing.
There are many , or several ways to do just about anything.
Don't fear it, try it.
If it blows up in yer face, buy a new face. ;D
Postby Mash » Wed Oct 26, 2016 5:51 am
Myles wrote:Most of the time, even when making genever, you have a clean base spirit before flavouring.
Very succinct. Spot on
Postby guest5234 » Wed Oct 26, 2016 7:28 am
I am going to send you my first bottle of gin as you have been so helpful ;D
guest5234
