Can't wait to see some photos !! Congrats on your new setupgaza the instructor wrote: Thu May 21, 2020 9:43 am It is just fascinating watching the product dance, better than T.V.
My bro said that looks like a mad laboratory experiment, so we have
called her, Frankenstill.![]()
Where I am today
Forum rules
Be Nice. NO POLITICS
Re: Where I am today
- buffalobob
We all care Robert, how could anyone not care. It stresses me seeing wildlife struggle but even more if I don't do anything about it. You deserve a slap on the back (from someone with 2m arms obviously
I'm pink therefore I'm spam
- Easydrinker
Today I fired up a still for the first time in more than 10 weeks.
Beer and wine had kind of taken over.
I had forgotten the sweet sound of rattlin' copper pieces.
Robert,
Robert,
Easydrinker wrote: Mon Apr 08, 2019 12:38 am It is late, and I am a little pished.
Why not borrow from the old site a popular topic..,...
Post by YHB » Sat Mar 02, 2013 1:57 pm
I had a Clarinet lesson.
Not really true the last line, but here I welcome all to mention something significant in their day.
I used to play second Oboe with Bolton youth orchestra. Honest Injun!
Have you tried turning it off and back on again?
Vir prudens non contra ventum mingit.
If it’s broken, it might be my fault, is my responsibility and there is even a slight chance I can fix it
- Easydrinker
Now, that is really diggin' in the archives!
- DorsetScott
Today, I finished my sacrificial run on the new still spirits alembic pot condenser setup, after the vinegar run yesterday, so now we're cooking on gas.
It's not perfect, it's running off my brewzilla so I don't have power control, only temp, but it strips a LOT quicker than the airstill I have been running. I have an alcoengine reflux incoming when it's finally shipped, and eventually will get a power controllable boiler, but right now it's a step up which suits my circumstances and I'm very excited.
I'm not under the affluence of incahol, thinkle only peep I am. Its just the drunker I sit here the longer I get.
Can you set the brewzilla to full boil on its controller (effectively bypassing it) but use a plug in power controller?
To Gin-finity and beyond !
- DorsetScott
No, unfortunately not. I think I'd risk messing with the internals if I did. It's pretty cheeky, it's marketed as able to distill in the same way as the grainfather, but doesn't have the ability to switch to power mode. It's either a 500w,1900w or both element running, so while it "can" its not elegant.Mash wrote: Mon May 25, 2020 7:31 am Can you set the brewzilla to full boil on its controller (effectively bypassing it) but use a plug in power controller?
There appears to be minimal info out there on how to use it for this purpose and a lack of real life experience reports.
Like I say it will do me for now, and I'll almost certainly end up with the t500 boiler and a power controller when funds allow.
Can you access the elements. If so you could easily rewire them.
Searching the Web, seems to show a plate on the bottom - very similar to how most burcos are built.
Whip that off, install a separate socket, & Roberts your mother's brother?
Moss wrote: Sat May 23, 2020 11:12 pmEasydrinker wrote: Mon Apr 08, 2019 12:38 am It is late, and I am a little pished.
Very cool Moss
Do you still play?
- gaza the instructor
One of our favourites Mash.Mash wrote: Mon May 25, 2020 7:31 am Can you set the brewzilla to full boil on its controller (effectively bypassing it) but use a plug in power controller?
https://www.ebay.co.uk/itm/AC-220V-4000 ... 40db79e5fe
Mirror-signal-manoeuvre.
Sure is. But they seem a bit expensive at the moment.
This is the fella.Mash wrote: Mon May 25, 2020 10:06 am Can you access the elements. If so you could easily rewire them.
https://rover.ebay.com/rover/0/0/0?mpre ... 2420302682
I just bought one of these Mash .https://www.ebay.co.uk/itm/AC-220V-4000 ... 0005.m1851
I lost this post the first time around so retyped it all again but I apologise if I forgot some diplomacy!Mash wrote: Mon May 25, 2020 12:53 pmThis is the fella.Mash wrote: Mon May 25, 2020 10:06 am Can you access the elements. If so you could easily rewire them.
Please don't take offence Mash, I am not sure I would do that for two reasons:
Firstly, I doubt that plug and socket combination are up to running 2.4kw for extended periods. The limited contact area and the poor provision for wiring them up risk them overheating. If you want that style of plug and socket google 'iec hot sockets' for more suitable construction. I use the round blue 'caravan' 16A plugs and sockets with immersion heater cable to wire them up. Admittedly bulkier, but not much more expensive and better designed to connect the wires.
Secondly, unless the original controller is disconnected from the elements, if the original controller is ever used, the exposed pins on the modified plug would become live. I guess you intended that they were removed, that however stops the original temperature controller mode functioning.
If, as I suspect, the original controller uses mechanical relays there is an alternative solution. Wire in one of those cheap chinese phase angle controllers between the original controller and the 1900w element. At full power on the old controller, you will be able to adjust from 500w to 2.4kw and on the 1900w setting from zero to 1900w. It won't upset the original function of the controller if you set the phase angle control to 100%, in fact you could have better temperature control with less overshoot with finer control of the heating power.
DorsetScott, If you think this mod would be of value I, as others on here no doubt, would be very happy to walk you thru the upgrade.
The type of controller you will be looking for is one that can be wired either way around, input or output to the mains and the heater on the other connection. As the chinese always overstate the capabilities of their products go for a 4kw one.
One of the guys on here did something similar a couple of months back and put it in a nice box with a power meter. If it were me I would fit it in the bottom of your boiler (you don't need the power meter). My estimation of the work involved would be to drill a hole for the control knob to fit thru and connect up 3 wires inside the boiler.
Zio Roberto!
Jennysgin wrote: Mon May 25, 2020 10:26 amMoss wrote: Sat May 23, 2020 11:12 pmEasydrinker wrote: Mon Apr 08, 2019 12:38 am It is late, and I am a little pished.
Very cool Moss![]()
Do you still play?
Unfortunately not. I gave up when I realised that I couldn’t be arsed.
I was hard work when I was a teenager
Not fair I don't have a red button, mine are all black or are we not
allowed to say that word. My buttons are all Dark! No I was right
they are all Black with a little bit of White, like Croydon.
Aww, that's a shame Moss
Although that seems to be the common path teenagers take
- Easydrinker
I had a Clarinet once. The only piece that I could play was 'Stranger on the shore'.
I still own an Alto Sax. It could tell a few stories, but has not seen daylight for 10 years or more.
- Easydrinker
I've been playing 'hunt the red button', not seeing one here.
- buffalobob
- Easydrinker
Got the polytunnel re-covered today.
Much work, but should be good for another 5-7 years.
We drag the new cover over the old, and when happy, withdraw the old and fix the new.
This method means at times there is no air circulation in there.
The internal temps, got up to 48.2°C.
That was fookin' hot!
Ma Haggis sandwich in ma Sporran was starting to get wet and greasy!
Hmm that's got me thinking.. What's the benefit of dragging the new cover over the old?
- Easydrinker
You can do it , with fewer helpers, without disturbing anything growing inside.Mash wrote: Thu May 28, 2020 7:20 am Hmm that's got me thinking.. What's the benefit of dragging the new cover over the old?
My toms are supported by 6 foot canes, the hoops are maybe 7-8ft tall, we didn't knock any canes in the process.
Having done this twice now, I would stick with the method, it seems pretty easy.
Oh, another benefit, free range poultry cannot get in there while your hoops are naked.
Several years ago I was working away from home, drove back up the road to see a door had blown/been left open, the feckers were in there and had spent sometime scratching up everything.
